Mattaxi Samba Member
Posted: Sun Dec 04, 2016 1:49 pm Post subject: Shrinking Door panel vinyl |
Hi, I took out the old original 1958 door panels as the cardboard type og material needed replacing. I created new wood similar to og material using the template of the old material. I went to re fit the vinyl and i am about 1.5-2cm off. is it possible that the vinyl shrink? The og vinyl was stored in humid and cold environment. What can I do to expand the vinyl to fit the panel?
Could I leave them in the sun for some time or will it make it worse? |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sun Dec 04, 2016 1:52 pm Post subject: Re: Shrinking Door panel vinyl |
yes warm it up in the sun or with a heat gun or hair dryer _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Sun Dec 04, 2016 1:57 pm Post subject: Re: Shrinking Door panel vinyl |
Tks mate, do you think I will get the 2cm by doing that, and do I have to staple the vinyl to the panel immediately? bdw the og vinyl got abit wavy as well |
Posted: Sun Dec 04, 2016 2:04 pm Post subject: Re: Shrinking Door panel vinyl |
it will be close and I would use a glue also. I had one redone on my 64 years ago and it turned out good. _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Sun Dec 04, 2016 2:07 pm Post subject: Re: Shrinking Door panel vinyl |
tks mate much appreciated will see how it turns out |
GB2S Samba Member
Posted: Wed Dec 07, 2016 7:43 am Post subject: Re: Shrinking Door panel vinyl |
How do you remove the old glue residue off the vinyl? Call an upholstery shop for stretching ideas, and possibly installation.
Geoff _________________ 1963 Ragtop |
Posted: Wed Dec 07, 2016 11:59 am Post subject: Re: Shrinking Door panel vinyl |
Is the residue you are talking about brownish like wooden flackes? If yes do you think I should remove it first before stretching? and do you think that by stretching the material I would be able to get my 1.5-2 cm difference? |
carcrazed Samba Member
Posted: Wed Dec 07, 2016 12:58 pm Post subject: Re: Shrinking Door panel vinyl |
Normally, those brown flakes is the old glue that has deteriorated. On my 61, I ended up using the original vinyl and door card material. After soaking the vinyl with some quality vinyl treatment to soften it as much as I could. I then set the vinyl and card out in the sun to warm it up. I worked with spray adhesive from the middle out towards the end little by little also using a hair dryer to warm the vinyl. Mine stretched out considerably and is still in good shape. I am pretty sure mine was shrunk at least 1/4 inch and when I heated it up in the sun and with a hair dryer, I had plenty to work with. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
GB2S Samba Member
Posted: Thu Dec 08, 2016 8:51 am Post subject: Re: Shrinking Door panel vinyl |
How do you remove the old glue from the vinyl? What is the vinyl treatment that is used?
Posted: Thu Dec 08, 2016 8:57 am Post subject: Re: Shrinking Door panel vinyl |
Elbow grease. I used a scotch brite pad gently to scrape off the old glue. There is no way to get all of it off, just the loose stuff. _________________ 1965 Herbie Replica. 1776cc dual Kads.
Posted: Sun Feb 19, 2017 9:52 am Post subject: Re: Shrinking Door panel vinyl |
Hi guys, tried the methods above and altough i am getting near the correct size, i cannot quite get the 1 inch that i want? Any one has another solution? I suspect that the old glue residue is making the door panel upholstery un flexible |
