Rob356 Samba Member
Joined: November 26, 2016 Posts: 13 Location: Cleveland, OH
Posted: Sun Dec 04, 2016 3:20 pm Post subject: 1965 Type 3 Notchback |
Hey all - Just picked up this Notch and I'm not a specialist. I have restored bugs to original condition. First question, is the front apron originally spot welded on or is it bolted on. The car has typical battery box rust so I need to replace it and in front. Is IPS the best place for these to begin? Also need to replace all wiring. I will not be going all the way back to a concours because the pan has been replaced and it has been converted to 12 volt and also has a dual port engine. So my best option is a decent show-car/driver. So if you could help with best places to get parts, I am located in the Cleveland, OH area. Thanks Dan for the recent contacts.
DQDan Samba Member
Joined: October 24, 2016 Posts: 351 Location: Cleveland OH
Posted: Sun Dec 04, 2016 4:52 pm Post subject: Re: 1965 Type 3 Notchback |
Welcome to TheSamba! It was nice meeting you and I look forward to the future of our projects!! |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Sun Dec 04, 2016 6:59 pm Post subject: Re: 1965 Type 3 Notchback |
Welcome to The Samba!
Stuff is jumping off in Ohio!
Yes, ISP West, & West Coast Metric will be your best sources for T3 stuff. JBugs has some too. _________________ Everything known to man has been written.
Readers are Leaders! |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3695 Location: San Jose, CA
Rob356 Samba Member
Posted: Wed Dec 07, 2016 6:35 pm Post subject: Re: 1965 Type 3 Notchback |
Hey All,
OK been digging into this project, it looks like at some point the pan was replaced with a 1972 pan, which would explain the dual port heads, 12 volt, high back seats and the 4 bolt lugs. My question to you is I will be building a nice show car/ driver and with the 12 volt, disc brakes, and updated engine, I feel it is a good combo. Give me some feed back/ pros and cons? Anything would be helpful and greatly appreciated. |
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1876 Location: Feeling, Minnesota
Posted: Wed Dec 07, 2016 6:59 pm Post subject: Re: 1965 Type 3 Notchback |
Looks like a fun project. Is it swing-axle or double-jointed? _________________ 1988 Ford Festiva L
1965 Honda 50 "Super Cub"
2016 Miami Sun Trike |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22432 Location: Kimball, Mi
Posted: Thu Dec 08, 2016 3:19 pm Post subject: Re: 1965 Type 3 Notchback |
My big question would be how did they(the PO) set up the engine hanger set up?? Did they swap out the rear subframe for a Swing Axle set up? Or keep the IRS? Just asking, as that'll help us let you know what your options are.
My own 65 Notch has IRS and I welded in some some stock IRS engine hanger mounts, and used the IRS hanger bar on my engine. It's a fantastic cruiser. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Rob356 Samba Member
Posted: Thu Dec 08, 2016 7:35 pm Post subject: Re: 1965 Type 3 Notchback |
Its a swing axle set up with the hanger. But it does have the IRS mustache mount on the engine. I will take that off.but need to get the fan off first. I just started tearing down the dual port engine. I don't mind the swing axle, had one on my 64 and 65 bugs. |
Rob356 Samba Member
Posted: Thu Dec 08, 2016 7:40 pm Post subject: Re: 1965 Type 3 Notchback |
Here's a couple of updated Picts |
Posted: Fri Dec 09, 2016 12:07 pm Post subject: Re: 1965 Type 3 Notchback |
Rob356 wrote: |
If you're planning on rebuilding the engine, and adding full flow oil filtration, you might want to keep part of that bar (like John J. did on his 66 Square), as it'll work great for mounting the oil filter (and adapter unit) to it. That way, when you decide to pull the engine in the future, it'll come out with it already attached (1 less thing to disconnect before pulling the engine). Other than that, you might want to check and see if you have the rear "donut" part for the upper rear hanger, and the 5 phenolic shims that go with it, to help set the tension on it, as it's really a snubber, not a mount.
Nice looking project you've got though.
As for the high back seats, are they 3 point? Or are they 2 sliders? Just asking, as 72 is a transition year and can have either 1. If it's the 2 slider type, earlier low back seats will directly slide on if you want them. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Rob356 Samba Member
Posted: Fri Dec 09, 2016 9:57 pm Post subject: Re: 1965 Type 3 Notchback |
Thanks for all the info! Nice on the additional oil cooler idea.
The seats are the 2 slider version. I just ordered the donut snubber and the 1/4 floor pans to replace ones that are not too bad, except battery box as usual. Just to thin for my liking, so replacement time. I know one thing, it's gonna take a lot of hammer and dolly time. I will metal finish most that I can. I'll keep the pictures coming. Thanks all. |
Rob356 Samba Member
Posted: Wed Dec 14, 2016 8:16 am Post subject: Re: 1965 Type 3 Notchback |
I found that the bottom door hinge on both sides is "loose". The allen head screws are tight, but the bottom hinge moves when you open and close the doors! What is the fix for this and have you seen it before?? |
Rob356 Samba Member
Posted: Sat Jan 07, 2017 5:15 pm Post subject: Re: 1965 Type 3 Notchback |
Some update pictures. After 2 weeks roof is finally straight & in primer!
A little paint sample of 1965 Sea Blue - love that color!
_________________ 1964 bug - drag car
1965 bug - original resto
1957 356A
1965 Notchback - current project |
Posted: Sat Jan 07, 2017 9:08 pm Post subject: Re: 1965 Type 3 Notchback |
That's going to look sweet. I love the Sea Blue color, and after seeing it on Pedro's Notch, I know yours will look fantastic. My T-34 was Sea Blue#2, and I really liked that color. I almost painted my 65 Notch that color after I sold my T-34, but in the end I kept the metallic blue color I had shot it back in 2000 (it's a BMW color). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Rob356 Samba Member
Posted: Mon Sep 27, 2021 11:37 am Post subject: Re: 1965 Type 3 Notchback |
Finally back on the project! I just pulled the transmission out and the part number that I came up with on the side of the transmission is 113301103D.
Can anyone help me identify what year the transmission is. The body is a 65 and the pan is a 72. It is a swing axle and I will be replacing I’ll gaskets and checking the sink rose and shift forks. I did identify the engine as also in 1972. So if anyone could help me with a D in the transmission I would appreciate it! _________________ 1964 bug - drag car
1957 356A
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Mon Sep 27, 2021 12:39 pm Post subject: Re: 1965 Type 3 Notchback |
Here's a good place to start:
http://vw.zenseeker.net/Transaxle.htm
The numbers on the side are not going to tell you what someone did on the inside if it's ever been opened. You have to open it up and check it out (or send it out to be rebuilt to your specs).
In addition to the part number you found - there should be a serial number stamped into the case of the transmission. |
Rob356 Samba Member
Posted: Mon Sep 27, 2021 5:54 pm Post subject: Re: 1965 Type 3 Notchback |
Thank you for the help, I will look it up and get the serial number. Tearing it down now to see if everything is still in spec. Leaking like a sieve will be replacing all gaskets and seals. Mounts also broken, need to make sure it goes back together correctly! _________________ 1964 bug - drag car
1957 356A
