914RS Samba Member
Joined: September 13, 2004 Posts: 16 Location: DeLand, FL
Posted: Tue Jan 17, 2017 4:59 pm Post subject: Re: Experimental Fuel Injectors for 2.1. Surprising Results. |
You may notice that the CB fuel rails have inlets to the injectors that are more narrowly spaced than the bases on the factory manifolds.
If there is interest in some kits, I will machine fuel rails for this application so everything is square. |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Wed Jan 18, 2017 8:55 pm Post subject: Re: Experimental Fuel Injectors for 2.1. Surprising Results. |
If you can come up with a ball park number for your kit, I'd maybe go for one.
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
914RS Samba Member
Posted: Thu Jan 19, 2017 9:02 am Post subject: Re: Experimental Fuel Injectors for 2.1. Surprising Results. |
I'm thinking about $250 for:
4 Rebuilt Bosch EV6 injectors (with warranty, no core)
2 Fuel rails
and all the hardware, fittings, hose and hose clamps.
I'm still in the testing phase and would need to set up the machine processes for the rails. |
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Thu Jan 19, 2017 9:25 am Post subject: Re: Experimental Fuel Injectors for 2.1. Surprising Results. |
OK- it can be done. But answer, please: 1) does it change the fuel efficiency (gas mileage) measurably? and 2) does it give higher horsepower?
(ps, I've got a couple of 914s myself) |
danfromsyr Samba Member
Posted: Thu Jan 19, 2017 9:58 am Post subject: Re: Experimental Fuel Injectors for 2.1. Surprising Results. |
there are injector hose adapters out there to keep your old (updated) fuel rail
Abscate wrote: |
914RS Samba Member
Posted: Thu Jan 19, 2017 1:03 pm Post subject: Re: Experimental Fuel Injectors for 2.1. Surprising Results. |
That's a genius adapter. Really cool.
However, I think we all know the rubber "retainers", and I use that loosely (pun intended), are a pretty unreliable method of injector retention in the manifold. I see Vanagons regularly with idle problems that can be traced to the injectors floating around in their mounts.
I've been looking at the numbers on producing a kit this afternoon, and I'm now thinking about $190 for everything, which I would think would be fairly practical pricing. |
914RS Samba Member
Posted: Fri Jan 20, 2017 7:00 am Post subject: Re: Experimental Fuel Injectors for 2.1. Surprising Results. |
pinetreeporsche wrote: |
The two problems I'm attempting to address are fuel milage and availability. I know there are Lucas injectors that work, but I'm not putting Lucas anything on my vehicle. I'm trying to see if I can provide an affordable upgrade using Bosch EV6s.
Also, EV6s are made to work with ethanol mixed fuel while the EV1s are not.
I'm not planning to dyno the engine. It's not exactly a high-specific-output 2.1 at 43hp/L. However the fuel milage and quality of the tune are certainly improvable, and that's what I'm after.
I'll be in the testing phase for at least another month. I can tell you that the current injectors are a little lean under acceleration. I may get an adjustable FPR to get them dialed in. When I find the sweet spot, I'll probably get another set of injectors with flow to match at the stock pressure. |
ezee Samba Member
Joined: July 21, 2013 Posts: 14 Location: Vancouver, BC
Posted: Mon Dec 18, 2017 2:02 pm Post subject: Re: Experimental Fuel Injectors for 2.1. Surprising Results. |
Wondering if anyone has updates on their progress on this experiment. I recently picked up a set of original (used) fuel injectors for free, and was going to send them to WitchHunter for cleaning, but then came across this topic, and it looks promising. |
Posted: Tue Dec 19, 2017 3:07 pm Post subject: Re: Experimental Fuel Injectors for 2.1. Surprising Results. |
Bump _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
