Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Mon Dec 12, 2016 3:57 pm Post subject: Can convertible top be moved manually? |
I'm buying a 2006 Beetle at a really good price. Only issue is the top won't open or close with the switch. Can the top be opened or closed by hand? |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Mon Dec 12, 2016 5:35 pm Post subject: Re: Can convertible top be moved manually? |
Yes, but you will be pushing it against the hydraulics. Just gently push against the top & it will slowly bleed off fluid, but it will take a few minutes. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
73sports Samba Member
Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
Posted: Mon Dec 12, 2016 7:38 pm Post subject: Re: Can convertible top be moved manually? |
There is a valve that can be opened on the pump, so you won't be fighting it, when operating manually. There should be instructions in the manual for emergency operation. _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Tue Dec 13, 2016 8:12 am Post subject: Re: Can convertible top be moved manually? |
This ^
There is no good deal on a convertible Beetle, they are all terrible when it comes to the top operation. Wait till the windows stop working.
You heard it here first. |
Posted: Wed Dec 21, 2016 3:36 pm Post subject: Re: Can convertible top be moved manually? |
And what is the problem that the windows stop working? |
Posted: Thu Dec 22, 2016 7:09 am Post subject: Re: Can convertible top be moved manually? |
Most of the operating gear of the Beetle convertible is not reliable. The window regulators are cheap and break. From my understanding with my contacts, they are not cheap to replace. The last time I saw an estimate to replace them was $1000. |
Posted: Thu Dec 22, 2016 7:46 am Post subject: Re: Can convertible top be moved manually? |
If you think a Bentley manual is expensive, wait until you have to start repairing this beast. If the safety switches for the top go bad (or get misaligned), you can't start the car. I hope you haven't bought it yet.
Here's what you have to replace if the rear regulator goes bad
They make a repair kit to replace just the cable, but if either of those little white rollers is broken, you have to buy the whole $630 part. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Dec 22, 2016 6:10 pm Post subject: Re: Can convertible top be moved manually? |
So is it mostly the cable that is breaking? |
Posted: Thu Dec 22, 2016 9:28 pm Post subject: Re: Can convertible top be moved manually? |
Let's not spread rumors now. There is nothing that electrically connects starting the car and the top! Of all the switches on the top, I have only ever seen the one in the header that tells the car the top is locked closed, and the one on the right side ram go bad. Of course as the cars get older other things can go. I have repaired plenty rear window regulators, but have not seen the rollers broken. Before the repair kit was available, the only option was the whole assembly. _________________ I will never lie, but sometimes the truth changes.
Posted: Fri Dec 23, 2016 1:03 am Post subject: Re: Can convertible top be moved manually? |
73sports wrote: |
Let's not spread rumors now. There is nothing that electrically connects starting the car and the top! Of all the switches on the top, I have only ever seen the one in the header that tells the car the top is locked closed, and the one on the right side ram go bad. Of course as the cars get older other things can go. I have repaired plenty rear window regulators, but have not seen the rollers broken. Before the repair kit was available, the only option was the whole assembly. |
Oops, I guess it was the Audi cabs I was remembering. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
crsmp5 Samba Member
Posted: Fri Dec 23, 2016 5:25 am Post subject: Re: Can convertible top be moved manually? |
i know a guy who shorted a brake light bulb holder harness.. it breaks its wires at the trunk hinge... poof comfort control modual now fried.. just from opening the trunk to replace a tail light bulb... was a $1k+ wtf...
ive done a rear regulator.. 1st and last... _________________ [url=http://cdn2.driiive.com/7037.jpg]Click to view image[/url] |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Sun Jan 01, 2017 3:33 pm Post subject: Re: Can convertible top be moved manually? |
The owners manual it tell you how to put the top down without power. _________________ Good Luck
Al |
