EmpiGT Samba Member
Posted: Wed Oct 14, 2015 11:33 am Post subject: |
Not to burst your bubble. I have only seen adjustable spring plates for lengthened short axle tubes (short end casting) or if you narrow the torsion housing. To run that axle as is you will have to have offset plates if you find adjustable offsets let us know. |
cww Samba Member
Posted: Wed Oct 14, 2015 6:12 pm Post subject: rear wheel cylinders |
Trying to lower a 58 panel. Upgraded to dual mc, trying to bleed brakes starting with the closest. End up pushing out rear wheel cylinders. Trans is stamped 113 301 103. Has 41 above that & A0506424 below it. Old drums stamped 113 501 615 G. Bought new wide 5 drums. Cylinders are flaps quality. Any ideas? Maybe wrong shoes? Thanks for any help. |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Wed Oct 14, 2015 7:56 pm Post subject: |
Did you adjust all the shoes out before bleeding the brakes? Sounds like the cylinders blew out from excess travel. _________________ Tim |
cww Samba Member
Posted: Wed Oct 14, 2015 7:58 pm Post subject: |
Yes, I should have mentioned that. |
jacopotex Samba Member
Joined: June 05, 2015 Posts: 76 Location: gorizia italy
Posted: Thu Oct 15, 2015 8:37 am Post subject: |
EmpiGT wrote: |
in conclusion you are tell me that i can not use the adjustable spring plate, but only the offset spring plates
maybe is possible to use the adjustable plates, adding a piece for the offset? |
EmpiGT Samba Member
Posted: Thu Oct 15, 2015 8:50 am Post subject: |
jacopotex wrote: |
EmpiGT wrote: |
Unless you want to lengthen the tube on a set of short endcasting axle tubes. You cant run those adjustables as is. I'm surprised no one has made adjustable offset plates. It can be done. You will have to cut the adjustable plates and weld on the offset spacer and the part that bolts to the axle like the offsets have. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Thu Oct 15, 2015 9:13 am Post subject: |
EmpiGT wrote: |
jacopotex wrote: |
EmpiGT wrote: |
I have always wondered why offset springplates became so popular. I guess it's because they are easier. But modifying the stock plates and lengthening the short casting axle tubes isn't difficult. And it's much cheaper. _________________ nothing |
Posted: Fri Oct 16, 2015 2:01 pm Post subject: |
EmpiGT wrote: |
what do you mean with narrow the torsion housing? do you have a photo?
i'm studying the easy way for me for low the max possible my SC |
Posted: Fri Oct 16, 2015 4:48 pm Post subject: |
jacopotex wrote: |
EmpiGT wrote: |
Narrowing the torsion housing is a huge job, especially for an amateur builder. I would recommend you leave that option out for now.
Get a set of offset spring plates. They are the most simple option.
The highlighted words in your post are counteractive. Going low is easy, going slammed is not. _________________ nothing |
Posted: Sat Oct 17, 2015 12:52 am Post subject: |
cdennisg wrote: |
EmpiGT wrote: |
jacopotex wrote: |
EmpiGT wrote: |
I have always wondered why offset springplates became so popular. I guess it's because they are easier. But modifying the stock plates and lengthening the short casting axle tubes isn't difficult. And it's much cheaper. |
found on wagenswest the adjustable offset spring plates
easy way top for me
http://www.wagenswest.com/partstore/index.php/bus-...lates.html |
Posted: Sat Oct 17, 2015 1:07 am Post subject: |
cdennisg wrote: |
jacopotex wrote: |
EmpiGT wrote: |
The highlighted words in your post are counteractive. Going low is easy, going slammed is not. |
i will follow your advice, nut it's possible to see a photo for information only |
Posted: Sat Oct 17, 2015 8:02 am Post subject: |
jacopotex wrote: |
cdennisg wrote: |
jacopotex wrote: |
EmpiGT wrote: |
I just did some searching and cannot find a build thread or anything specific regarding narrowing the torsion housing. I know it is here, but I cannot find it. I did see some photos in the beetle section, but still no build photos, only finished product. _________________ nothing |
Posted: Sat Oct 17, 2015 8:03 am Post subject: |
jacopotex wrote: |
cdennisg wrote: |
EmpiGT wrote: |
jacopotex wrote: |
EmpiGT wrote: |
easy way top for me
Cool. I had not seen those before.
I'll save $400 and make my own stuff/trade for stuff. _________________ nothing |
Posted: Sun Oct 18, 2015 3:58 am Post subject: |
cdennisg wrote: |
jacopotex wrote: |
cdennisg wrote: |
EmpiGT wrote: |
jacopotex wrote: |
EmpiGT wrote: |
easy way top for me
I'll save $400 and make my own stuff/trade for stuff. |
yes it's so cool, now i'm only looking all the possibilities way, and than i will value and decide |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Fri Oct 23, 2015 2:34 pm Post subject: |
can someone visually tell if this is a long axle?
_________________ 1957 Beetle
1966 Bus |
WideFive SBS Hit Squad
Joined: August 20, 2002 Posts: 1147 Location: Litchfield, Ohio
Posted: Fri Oct 23, 2015 2:58 pm Post subject: |
Thanks Aaron! _________________ 1957 Beetle
1966 Bus |
whitneyco Samba Member
Joined: August 27, 2012 Posts: 5 Location: Lewisville, Texas
Posted: Sat Oct 24, 2015 6:08 am Post subject: IRS conversion brake line parts and mounting locations |
Newbie here, sorry if this is not the appropriate thread for this. I'm in the process of installing a Bus Boys IRS lowering conversion on my 63 Panel. It's a well designed conversion kit, but I need a little direction running brake lines and hoses. The trailing arms are from a 73 Beetle that were stripped of brake lines so I am unsure of exact brake line locations and mounting points. I assume I need to use Beetle part numbers, line lengths, hoses, Tee location, and mounting locations? Wolfsburg West has a diagram, but actual photos would be more useful. Does anyone have photos of brake lines installed on Splitty running late model Beetle trailing arms? |
Finbay Samba Member
Posted: Mon Nov 02, 2015 12:55 pm Post subject: |
Hello, i´m not sure if this is the right place to ask, but i´m asking anyway: I have 1966 split screen, and I would want to remove the reduction boxes and lower the rear a bit. I have an 1965 bug gearbox numbered 736 9091, drive axles and drums. Is this kit nearly "bolt on" or should I get something else? atleast the braking system needs upgrading.
And this is not the only question: I have heard rumors that 1968 typ2a front axle should fit to the split screen without major modification but can someone tell is this true? I have also an 1968 bay but at the moment i cant measure the axle.
Thank you in advance |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Mon Nov 02, 2015 6:21 pm Post subject: |
Finbay wrote: |
A 68/early 69 beam will fit. However, they RAISE the front ~1 to 1.5". You can lower them with adjusters and drop spindles. But it is more expensive than a link pin suspension and won't go as low. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
