74GhiaConvertible Samba Member
Posted: Fri Jan 20, 2017 8:07 pm Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
Floor pans primed, sealed, painted.
Posted: Sat Jan 21, 2017 7:37 pm Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
Took the vert top off and started cleaning the rear storage compartment...
Posted: Sat Jan 21, 2017 8:12 pm Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
Also took lots of pics removing the ragged top....
Posted: Sat Jan 21, 2017 9:15 pm Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
Posted: Sat Jan 21, 2017 9:20 pm Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
getting ready for tomorrow.
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Sun Jan 22, 2017 6:35 am Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
74GhiaConvertible wrote: |
Also took lots of pics removing the ragged top.... |
Nice work documenting deconstruction of the original top; that'll stand you in good stead when you install your new top |
Posted: Sun Jan 22, 2017 11:19 am Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
crocteau wrote: |
What are some of the better tops made in your opinion?
From what I've read you want to use wooden bows, there's three of them I believe.
I'm not sure I can install a top. |
Posted: Sun Jan 22, 2017 12:26 pm Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
I've been very satisfied with the canvas top kit I bought from Chucks Convertible Parts.
Two wood bows: header and rear... the mid bow is part of the frame.
Judging from the photos you're posting you apparently have both patience and skill. |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Sun Jan 22, 2017 1:06 pm Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
I believe these guys make the wood bows for everyone else. I've bought from them more then a few times.
http://www.mtmfg.com/vw/122/Karmann-Ghia-Convertible-Wood-Top-Bows _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
Posted: Sun Jan 22, 2017 8:45 pm Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
Thank you guys. It's going to be a while before I can afford to do the top. Maybe I will try it, maybe.
There's still a long list of items needed. Tires, license and tags, insurance, so we can get it going down the road on sunny days.
Thinking about using Grundy insurance.
Welded in some pieces to fix the holes in the rear compartment. Got it primed.
Will paint it tomorrow. Still need to undercoat the pans too.
Will take pics tomorrow. |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Mon Jan 23, 2017 8:34 am Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
If you haven't already, you should download the 1960 Karmann Ghia Shop Manual - Body Section - PDF from The Samba technical archives as it has a very detailed section at the end on how to replace the cabriolet top.
Additionally, there is also a seperate W Karmann Ghia Shop Manual - Ghia Top Assembly A83A - PDF document available for download as well.
Between the two, you should be able to get a clear enough picture of just exactly what that task will involve and whether or not you feel you may be up to trying it yourself. |
Posted: Mon Jan 23, 2017 7:19 pm Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
KGCoupe wrote: |
Thanks for the links. I skimmed over them. They will be very useful . |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Tue Jan 24, 2017 7:02 am Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
Thanks Nicholas ,I'm looking at these links now. |
Posted: Tue Jan 24, 2017 9:38 am Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
Installing Hushmat. It was easy to install and not very thick. Probably less than 1/8" thick. Works well on making things more quiet.
Posted: Tue Jan 24, 2017 9:39 am Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
Here's under the front floor pan before undercoating.
Posted: Tue Jan 24, 2017 1:36 pm Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
These original hinges are inoperable. I'll just make some out of stainless.
Posted: Wed Jan 25, 2017 9:08 am Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
All 39 sq ft of Hushmat was installed on the floor and rear area. Installation was simple, peal and stick and roll with the roller. I didn't stick any down under the rear shelf, below the hinge area as it will be to hard to remove in the future.(next body off resto) I'll use some material that can be slid in and out when needed. The original piece of insulation was desintagrated and trashed.
Next will be license, tags, inspection, and insurance. Still leaning towards Grundy. Anybody here use Grundy insurance? I was quoted $235 per year since the Ghia won't be a daily driver. |
Posted: Wed Jan 25, 2017 9:31 am Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
Is the insurance quote of $225 a year for an agreed upon value ? If not keep looking. _________________ ----------------------
Posted: Wed Jan 25, 2017 1:18 pm Post subject: Re: 1974 Karmann Ghia Convertible...finally getting started. |
Let's see what we can do here......
