Telephunken Samba Member
Joined: November 23, 2004 Posts: 274 Location: Northern California
Posted: Sat Dec 24, 2016 2:02 pm Post subject: Differences in early transaxles? pre 50, kdf, etc |
Can anyone tell me info on what the main differences are in the crash box transaxles from early splits? from like the war year kdf up to like 1950? I thought that the very early ones were aluminum and then at some point they switched to cast with maybe an aluminum nosecone; can anyone elaborate?? what changes were there and when?? I can't find any info in the forums...
Thank you. |
Posted: Sat Dec 24, 2016 3:44 pm Post subject: Re: Differences in early transaxles? pre 50, kdf, etc |
im looking at a transaxle that appears to have an aluminum body but maybe a cast steel nosecone? both case and nosecobe
ne have kdf cogwheel logos....
any info anyone?? |
SplitPersonality Samba Member
Joined: September 26, 2004 Posts: 630 Location: Norway
Posted: Sun Dec 25, 2016 4:31 pm Post subject: Re: Differences in early transaxles? pre 50, kdf, etc |
The switch from alu to magnesium was in Feb 1951 - same time as the engine cases. |
Posted: Sun Dec 25, 2016 5:23 pm Post subject: Re: Differences in early transaxles? pre 50, kdf, etc |
thanks for info; so all transaxles pre 1951 were aluminum case? do you know changes that occurred regarding alum nosecones vs cast steel? im looking at a transaxle with kdf logos on the side, with an "H" in a circle above, and a "17" stamped below cogwheel; and has a steel nosecone.... |
Posted: Sun Dec 25, 2016 10:37 pm Post subject: Re: Differences in early transaxles? pre 50, kdf, etc |
Im going to have to disagree with your info. I have verified that two other transaxles i know of that both clearly have verifed serial numbers from 1950 are magnesium cases, not aluminum. One was reported original to the car. one serial number is May 1950. I also have seen a restored 49 chassis with a magnesium trans. So it seems that info of a feb 51 switch over is not accurate. So I would like to know when the change occured.
Thanks for any info someone can provide. |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1462 Location: Finland
Posted: Sun Dec 25, 2016 11:58 pm Post subject: Re: Differences in early transaxles? pre 50, kdf, etc |
Thanks for the info Mika. So it appears that some were beginning to be made in new material starting in March 49, and final full transition by the end of April '49.
Thanks again!
PS. Any info as to the use of steel nosecones on the early aluminum transaxles? were they all like that? |
Posted: Mon Dec 26, 2016 12:17 am Post subject: Re: Differences in early transaxles? pre 50, kdf, etc |
thanks for info Mika. |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 986 Location: Bath, England
Posted: Fri Dec 30, 2016 4:20 pm Post subject: Re: Differences in early transaxles? pre 50, kdf, etc |
I have an original May 47 gearbox, which has the yellow/brown painted steel nosecone, and so additionally they must also been produced after the war, or maybe using up old stock? |
