raygreenwood Samba Member
Posted: Fri Dec 30, 2016 8:21 pm Post subject: Part number assistance for type 004 four speed needed |
Ok....in my type 4 four speed (004) rebuild thread.....I am trying to provide as many part numbers for others as I can for bearings so they can be searched for by others.
I have provided the VW, SKF and Timken part numbers for the bearings and races for the pinion shaft.....but.....I have no number for an FAG tapered roller bearing.
My original black notebook has no FAG number which means I have not seen any in the transmissions I have opened.
The technical specifications/bearkng cross match list here on the Samba....while quite good is both slightly cryptic (dates and models wise)......and lists oddly.....VW part #s....and under the column header of "FAG psrt number".....all other part #s.
This list says that the FAG # for the pinion shaft bearing is 522937. I can find no reference for that online anywhere.
So if you have opened any 004's and/or have parts around.....can you please check for a pinion shaft bearing from FAG and post it.
Thank you!
Ray |
