Navy_Flyer Samba Member
Joined: January 08, 2012 Posts: 474 Location: Charlottesville, VA
Posted: Tue Jan 03, 2017 11:19 am Post subject: Front blower fan - blowing a fuse - FIXED |
My front heater fan was working OK, albeit squeaky motor on low and med speed. Now it is blowing a fuse every time I try to turn it on. Could it be the fan motor is finally kaput, or only the in-dash resistor? Not looking forward to a dash removal...... _________________ 1987 Westfalia, Automatic. EJ25 VANARU Conversion
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Terry Kay Banned
Posted: Tue Jan 03, 2017 11:25 am Post subject: Re: Front blower fan - blowing a fuse |
Kaput, Finito, Morta, Arriva Derchi.
It's all done, toast, fried. _________________ T.K. |
Posted: Tue Jan 03, 2017 11:41 am Post subject: Re: Front blower fan - blowing a fuse |
Thought so..... well at least I know what I'll be doing for the next couple of weekends. Thoughts on best brand of new blower? I see Meyle is avail from BD and Febi/Bilstein or Dansk/Thermex is avail from VC. Not sure of the brand at GW but they're on sale at GW and I have some unused GW Bucks.
Do any of the new fans have sealed bearings now? Geez - don't want to do this again anytime soon. _________________ 1987 Westfalia, Automatic. EJ25 VANARU Conversion |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Tue Jan 03, 2017 11:42 am Post subject: Re: Front blower fan - blowing a fuse |
it's time to play the "Taps"
I am my way to replace mine too.. but removing the dash! ! ! OUCH ! !
Posted: Tue Jan 03, 2017 12:27 pm Post subject: Re: Front blower fan - blowing a fuse |
0to60in6min wrote: |
It will certainly be a learning experience, but Ben's site gives a very exceptional step-by-step with photos to go along with your Bentley, so I am pretty sure it will go OK. Just go slow and ensure all the entanglements (wires) are disconnected... I plan to do some cleanup and preventative maintenance once in there, like a new fan resistor, heater core and etc.... _________________ 1987 Westfalia, Automatic. EJ25 VANARU Conversion |
bluebus86 Banned
Posted: Tue Jan 03, 2017 1:00 pm Post subject: Re: Front blower fan - blowing a fuse |
at first sign of bearingnnoise, stop using the fan, if so the fan will not be damaged and the bearings relibed for another three decades of service.
in this case, maybe your lucky and the fuse protected the fan electrically and you can simply relube it, so long as the windings did not short out or go open from excess current draw.
good luck
ps my fan currently sits unused as it has just started to make noise, one of these days I will deal with it. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Tue Jan 03, 2017 1:11 pm Post subject: Re: Front blower fan - blowing a fuse |
bluebus86 wrote: |
good luck
ps my fan currently sits unused as it has just started to make noise, one of these days I will deal with it. |
Maybe. But for ~$60 for a new blower and the labor (PIA) to take out the dash, I will replace it once I get inside. If it still works after autopsy I will put it in the 'spare parts' pile or just pay it forward. _________________ 1987 Westfalia, Automatic. EJ25 VANARU Conversion |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9808 Location: Mt Lemmon, AZ
Posted: Tue Jan 03, 2017 1:18 pm Post subject: Re: Front blower fan - blowing a fuse |
Navy_Flyer wrote: |
...Now it is blowing a fuse every time I try to turn it on. Could it be the fan motor is finally kaput... |
Maybe. Maybe even probably.
Mine did that but I was able to get it to run w/o the fuse blowing by abruptly switching to the high speed, once running I could turn it back to 1 w/o a problem.
At that point I drilled the Mullendore Port, lubed the bearing I could access, and all has been well in the many years since.
There may even be a way to nudge it a bit (possibly revealed in that same thread?). In any case, if you can get it to move at all and then lube it, there may be hope.
I don't think you have much to lose by trying something at this point. |
maco70 Samba Member
Joined: March 16, 2011 Posts: 456 Location: Montréal, Québec
Posted: Tue Jan 03, 2017 1:21 pm Post subject: Re: Front blower fan - blowing a fuse |
just be aware please...
A fuse is protection, so it means a lot of current ask.
Some, as we, have experienced a fire dash so be alert about it.
Hope it helps. _________________ Martin from Montréal
1986 Vanagon GL full camper westfalia
(brown/tan interior) |
bluebus86 Banned
Posted: Tue Jan 03, 2017 1:30 pm Post subject: Re: Front blower fan - blowing a fuse |
Navy_Flyer wrote: |
bluebus86 wrote: |
good luck
Maybe. But for ~$60 for a new blower and the labor (PIA) to take out the dash, I will replace it once I get inside. If it still works after autopsy I will put it in the 'spare parts' pile or just pay it forward. |
there have been rumors that the new blowers are not as well made as originals. so I plan to relube mine, after close examination of course. besure to research the reliability of the new fans. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Tue Jan 03, 2017 1:39 pm Post subject: Re: Front blower fan - blowing a fuse |
Ahwahnee wrote: |
Navy_Flyer wrote: |
Thanks - BTDT. I was nursing it that way for a couple of months. I think it's just toast now. _________________ 1987 Westfalia, Automatic. EJ25 VANARU Conversion |
Posted: Tue Jan 03, 2017 1:42 pm Post subject: Re: Front blower fan - blowing a fuse |
maco70 wrote: |
Hope it helps. |
Agree. It's time to just bite the bullet and get in there. Been wanting to for a while now anyway, just to clean up the rats nest of wires from the PO's if for anything else and was putting it off until absolutely necessary. It now is Absolutely Necessary. The good news is I can still do it on my own schedule. Since it is registered "antique" there is no inspection required in my state - I am responsible for the ensuring the safety aspects of operation are all in order. _________________ 1987 Westfalia, Automatic. EJ25 VANARU Conversion |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Tue Jan 03, 2017 1:51 pm Post subject: Re: Front blower fan - blowing a fuse |
Having had my dash in and out about 30 times when fabricating my front AC system, I can advise that it is not nearly as bad a job as many believe. Ben's instructions are right on and the tip about the heater controls is pure gold for saving time.
If you are working alone, (after disconnecting all the bits in Ben's photo guide), you should remove all the dash fasteners except the centre Phillips screw (right near the windshield), and that screw will hold the dash in place. Now sit on a board that straddles the front seats or on a crate between the seats, remove that last screw and pull the dash onto your lap. Now scooch your butt, with the dash on your lap, over to one door or the other. Easy peasy. Installation is reverse of this. BTDT.
One other tip: The 2 dash air vents are easy to remove and install and when re-installing the dash, you might find it a lot easier to install the dash first and then install the vents.
Here's a pic that Wildthings posted a long time ago. The grill is removed by pushing it to one side and then pulling it out. The tabs in the four corners then are accessible and you use a pick to pull the tabs toward the centre of the vent to release the whole vent.
_________________ '86 Syncro Westy SVX |
bluebus86 Banned
Posted: Tue Jan 03, 2017 2:41 pm Post subject: Re: Front blower fan - blowing a fuse |
it probably is pretty easy after thirty times, heck is probably a lot easier the fifth time verses the first. for me the first time, what a pain to even think about. I hope I never have to be really experienced with this, once is enough.,
check out the rubber seals on the air vanes in the ventilation system, if worn or missing, you get bothersome air leaks, replace if suspect with fresh. neoprene foam works good for seals, like wet suit material
service wiper system good connections, joints lubed, look for leaks.
heater core, probably it is fine, but since it is thirty or so years old, whats the labour saving doing it now verses when in fails, thats a what you have to ask, is the system do for a flush now?
do I stop there, new valve, new hoses, oh heck how about all new hoses to and from engine? snowball rolling down hill.
disconnect battery before dash removal!!!! plenty of unfused connections can be exposed
of couse you have taken proactive action on the fuel system in engine bay, new lined hoses, bulkhead fotting removal, pressure regulator vacuum hose upgrades, all metal fuel rails, all real show stoppers if failure, kaboom!!
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Tue Jan 03, 2017 3:00 pm Post subject: Re: Front blower fan - blowing a fuse |
bluebus86 wrote: |
...of couse you have taken proactive action on the fuel system in engine bay, new lined hoses, bulkhead fotting removal, pressure regulator vacuum hose upgrades, all metal fuel rails, all real show stoppers if failure, kaboom!!
good luck |
Yup - all done within a couple of months of ownership. _________________ 1987 Westfalia, Automatic. EJ25 VANARU Conversion |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Jan 03, 2017 6:45 pm Post subject: Re: Front blower fan - blowing a fuse |
Just in case you're the "$10-mod-easy-to replace <vs> $60-OG-pain-in-the-a$$-if-it-goes-again" type guy...
http://www.thesamba.com/vw/forum/viewtopic.php?t=623382&highlight=
Git 'r done!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Tue Jan 03, 2017 7:32 pm Post subject: Re: Front blower fan - blowing a fuse |
thinking about it....
they should put in a 3 sections dash board...
we just remove the middle section, the radio and replace the blower.. all could be done under 2 hours without stress and pain..
I am stressed out already just thinking about removing the whole dash board... ughh
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1890 Location: Sidney B.C. Canada
Posted: Tue Jan 03, 2017 7:59 pm Post subject: Re: Front blower fan - blowing a fuse |
Let us know how you get on with this. Pulling the fan off the shaft to get at the external side of the inboard bearing looks like a chore
I've got around four extra fans in my stash. Two good and two needing overhaul. If you manage to devise a good way of pulling the squirrel cage please post.
Alistair
bluebus86 wrote: |
there have been rumors that the new blowers are not as well made as originals. so I plan to relube mine, after close examination of course. besure to research the reliability of the new fans. |
_________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Tue Jan 03, 2017 9:16 pm Post subject: Re: Front blower fan - blowing a fuse |
Navy_Flyer wrote: |
My front heater fan was working OK, albeit squeaky motor on low and med speed. Now it is blowing a fuse every time I try to turn it on. Could it be the fan motor is finally kaput, or only the in-dash resistor? Not looking forward to a dash removal...... |
Did you try the "Mullendore Port" trick or is it too late?
http://www.thesamba.com/vw/forum/viewtopic.php?t=395661&highlight=mullendore _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
