911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Tue Jan 10, 2017 10:24 am Post subject: Pan gasket |
I have my buggy's body off the pan so I can do some refurbishing.
What you you guys use for a pan gasket? Regular VW pan gasket? |
jspbtown Samba Member
Posted: Tue Jan 10, 2017 1:29 pm Post subject: Re: Pan gasket |
Lots of people use the standard pan gasket. I have also used the foam gasket that goes between a pick-up bed and a cap. |
cdnltded Samba Member
Joined: March 13, 2015 Posts: 381 Location: Pincher Creek, Alberta
Posted: Tue Jan 10, 2017 4:16 pm Post subject: Re: Pan gasket |
not to highjack this thread, but is a pan gasket necessary?? |
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Tue Jan 10, 2017 4:22 pm Post subject: Re: Pan gasket |
The pan gasket seals the body to pan joint preventing water from splashing through the joint....keeps your feet a little drier! _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
Posted: Tue Jan 10, 2017 4:52 pm Post subject: Re: Pan gasket |
jspbtown wrote: |
I used this stuff on the bed of my old Ford Ranger, when I installed a canopy. Very easy to work with.
This might be the easiest way to go. |
bigfatloser Samba Member
Joined: July 27, 2014 Posts: 94 Location: High Desert Calif
Posted: Tue Jan 10, 2017 5:04 pm Post subject: Re: Pan gasket |
Straight body to pan on mine. _________________ DMZFAB.COM |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15278 Location: Deep in the 405
Posted: Wed Jan 11, 2017 3:50 pm Post subject: Re: Pan gasket |
Get a calking gun and a tube of auto body seam sealer. I've seen many use a tube of house calking or silicone. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Wed Jan 11, 2017 7:49 pm Post subject: Re: Pan gasket |
vwracerdave wrote: |
Get a calking gun and a tube of auto body seam sealer. I've seen many use a tube of house calking or silicone. |
i would think that auto seam sealer would give an unbreakable bond. like what do you do if you need to lift the body off for some reason |
joescoolcustoms Samba Member
Posted: Fri Jan 13, 2017 12:44 pm Post subject: Re: Pan gasket |
I have used the foam truck topper tape, the watertight curing sealer, and the original pan gasket.
Just like on my pickup truck topper, the foam seal worked it's way out on the ends.
The curing sealer worked great, but the issue if I had to remove the body would involve cutting it off like a old GM windshield.
The pan gasket tends to leak a little at the ends and is a PITA to hold in place while placing the body on.
Not a fan of body straight to chassis. The body moves a little no matter what you do. The fiberglass is like a harsh sandpaper and cuts the finish off of the chassis resulting in rust prematurely. I have taken several apart that were body-direct on the chassis and these were the only ones I have seen rust out the top of the pan mounting flange.
All have the pro's and con's. All of the recent buggies I have built have had the original pan gasket, with curing sealer on the ends. To keep in place, I use small stainless steel trim style screws to hold the gasket in place. Not too much to cut the body off if needed. At MOTB '16, I had my buggy in fresh water half way up the sides of the tub, and no water came inside from around the body seal. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Fri Jan 13, 2017 2:18 pm Post subject: Re: Pan gasket |
Thanks for the info. Presently, I'm leaning towards using the canopy tape, but I won't be putting the body back on the pan for another 2 or 3 months, so I have lots of time to change my mind.....and then chance it again.... |
