EBSTEVE Samba Member
Joined: September 11, 2005 Posts: 112 Location: Snohomish wa
Posted: Sun Jan 15, 2017 6:20 pm Post subject: Re: IDF/ #2 weak fire |
Like I said mine were never drilled by Weber and I have never done it. That all being said I would still and tap top and bottom and be done with it.
txoval wrote: |
If you go with the method shown at the link, you'd be depending on the o-ring at the plunger.
Can you not tap and plug the hole at the base? |
txoval Samba Member
Joined: January 23, 2004 Posts: 3540 Location: The Woodlands, TX
Posted: Sun Jan 15, 2017 6:36 pm Post subject: Re: IDF/ #2 weak fire |
I like the way you think. Easy to tap and plug both ways. Just curious how others were doing it |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3777 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Tue Jan 17, 2017 1:12 pm Post subject: Re: IDF/ #2 weak fire |
EBSTEVE wrote: |
I am at about 200'. I got the car to run on all 4 it was not linkage (it would do it without it hooked up).
I started with the air bypass screws at 1/2 turn out and got best lean in no time and the pump jets do nothing at idle. I drove the car and it needs a bunch more tuning / jetting but it moves along enough that I got a bit squirrely around a corner.
I have spent far too much time on my car and not enough with my family so I am going to fix the important one.
I will update when I finalize the jetting just in case anyone ever searches.
Thank you all for you help! |
At 200' you'll need either 47.5 or 50. No higher than 50. Go down on your vents 28-30 with a 125-130 main. 180-190 air corrector jets.
Get your hands on an LM-2 _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Wed Jan 18, 2017 7:25 am Post subject: Re: IDF/ #2 weak fire |
udidwht wrote: |
Get your hands on an LM-2 |
From what I have been told and read I thought the vents should actually be a bit larger with a 40mm intake valve, more between a 34-36. Won't a 28-30 restrict the motor at higher RPM's?
I am no expert but I am trying to understand before I go buying more vents and jets. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9665 Location: Oregon
Posted: Wed Jan 18, 2017 9:53 am Post subject: Re: IDF/ #2 weak fire |
Read every page and post from the link below. Read it twice. It will take days This will make you a better tuner and help you understand the way carbs work.
Good Luck.
EDIT, Forgot the link as I was running to a meeting.
http://www.thesamba.com/vw/forum/viewtopic.php?t=293837
EBSTEVE wrote: |
udidwht wrote: |
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Last edited by 67rustavenger on Wed Jan 18, 2017 12:57 pm; edited 1 time in total |
Posted: Wed Jan 18, 2017 10:14 am Post subject: Re: IDF/ #2 weak fire |
EBSTEVE wrote: |
udidwht wrote: |
That won't be an issue. If the vents are to big you have issues at idle. 28-30 is where you want to be. I'd start with 28mm. Also be sure you clean them (carbs) real good as well as the distributor. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
