bugheadred Samba Member
Posted: Mon Jan 16, 2017 7:24 pm Post subject: i need to change the door pins |
I need new door pins before I can get the doors aligned so I'm making this door pin remover
Irish911 Samba Member
Posted: Tue Jan 17, 2017 3:26 am Post subject: Re: i need to change the door pins |
Let us know how you make out? |
Posted: Tue Jan 17, 2017 9:25 pm Post subject: Re: i need to change the door pins |
all done haven't made the push pins yet thinking of using an old screwdriver total cost 13.00 if it works its the best 13 bucks ever spent lol
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9771 Location: Oregon
Posted: Tue Jan 17, 2017 10:07 pm Post subject: Re: i need to change the door pins |
Can you please write up a tutorial on how that door hinge pin puller works?
I can see how the top works. It's the leaver that confuses me. Do you hit it with a hammer? Or am I missing something?
Thanks for sharing your tool build. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Thu Jan 19, 2017 8:17 am Post subject: Re: i need to change the door pins |
Looks good
Question: How do you keep the driver pin (made out of the rod of a screwdriver) from sliding away at start?
Did you make an indent in the leverage beam? _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Posted: Thu Jan 19, 2017 3:56 pm Post subject: Re: i need to change the door pins |
ok so I bent the 1 inch bar stock on the first try
so I wielded on them 2 triangles and heat treated it . I put it in my wood stove for about 30 min. until glowing red quenched in used motor oil . then cleaned it up (after it was all the way cooled to room temp) got all the oil off and then baked it in my oven at 400 degrees for 2 hrs (its hard )
the push pins I made out of old head studs
to make the pins stay in place I drilled about 1/4 into the 1 inch bar you can see it in the last pic
grandpa pete Samba Member
Posted: Thu Jan 19, 2017 6:00 pm Post subject: Re: i need to change the door pins |
OK it works !
Where are you and how much is the rental ?
How much will shipping be ?
remember the other hinge tool required a $100 deposit so you make shure you get it back .
a little ospho and some primer and paint will keep my hands cleaner too _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Posted: Thu Jan 19, 2017 6:53 pm Post subject: Re: i need to change the door pins |
grandpa pete wrote: |
OK it works !
a little ospho and some primer and paint will keep my hands cleaner too |
I cost me 13.00 (you built a whole car you can just do it yourself I'm sure . if you need help let me know |
Posted: Thu Jan 19, 2017 7:22 pm Post subject: Re: i need to change the door pins |
OK ; can you give a breakdown on materials like the thickness of the side plates .
Is the threaded rod 1/2 inch ?
why did you weld the nuts to a small piece of bar before you welded to the side plate ?
Is the moving cross bar 1 inch by 1 inch solid bar ? _________________ 63 two fold rag
Posted: Thu Jan 19, 2017 9:39 pm Post subject: Re: i need to change the door pins |
the side plates are 1/4 thick plate that was given to me for scrap
the threaded rod was in my scrap pile also . it is thicker than half I think its 5/8
I welded the piece of square stock to the nuts so there was more surface wielded to the to the side plates . I also made the threaded rod longer than the side plates so when it got ruined I could screw it all the way in and cut it off so it could be unscrewed and replaced (the bad part on the end where it contacts the lever bar) and yes the lever bar is 1x1 bar stock |
tb03830 Samba Member
Joined: December 02, 2009 Posts: 1045 Location: Leavenworth, KS
Posted: Thu Dec 21, 2017 2:29 pm Post subject: Re: i need to change the door pins |
Thank you for this Thread. I am about to start building one with a company in town. Your dimensions helped a lot. A guy in the US use t build these but stopped and I would pay up to $200.00 for one but I am now seeing them for $400.00 or more. I can pay to have one laser cut for $100.00 or less if I weld it and wait twoo weeks.
Ingenuity is our (VW people) hallmark when people get greedy. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower. |
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Thu Dec 21, 2017 4:51 pm Post subject: Re: i need to change the door pins |
A little late to help me, I just got my door pins out, darn. But I have access to an entire metal shop, so if it's okay I'm going to build one of these to keep around. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
Posted: Thu Dec 21, 2017 5:50 pm Post subject: Re: i need to change the door pins |
Sqrbckguy38 wrote: |
A little late to help me, I just got my door pins out, darn. But I have access to an entire metal shop, so if it's okay I'm going to build one of these to keep around. |
that is why I put this up anything to help anyone keep these old fun cars on the road |
flyboat Samba Member
Posted: Thu Dec 21, 2017 6:27 pm Post subject: Re: i need to change the door pins |
So it appears the top of the pin has threads on it. Am I seeing that correctly? I think I'm wrong about that because the pin is pushed out, not threaded out
Any help is appreciated _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car |
Posted: Thu Dec 21, 2017 6:43 pm Post subject: Re: i need to change the door pins |
yes but so the mirror can screw on the hole for the pin don't have threads |
Posted: Thu Dec 21, 2017 6:51 pm Post subject: Re: i need to change the door pins |
[email protected] wrote: |
Gotcha, Thanks _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
Posted: Thu Dec 21, 2017 9:50 pm Post subject: Re: i need to change the door pins |
Most pins also have groves at the top of the pin also so it will not spin. The groves are vertical and are inside the whole when inserted. I want to do this so I can add a pin for eternal side view mirror on both sides. Mine currently has none. Not sure how it passed inspection in the past with out the Drivers side version at least. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Posted: Fri Dec 22, 2017 12:21 am Post subject: Re: i need to change the door pins |
tb03830 wrote: |
Ingenuity is our (VW people) hallmark when people get greedy. |
13.00 all together cost to me |
Posted: Fri Dec 22, 2017 10:07 am Post subject: Re: i need to change the door pins |
How wide is the whole to accommodate the threaded head on that door pin. It has to pass through the upper brace point to be pushed out. The whole has to be big enough to allow the head to pass through even with a screw head pin attachment for a mirror. Can you give it to me in milometers?
Thank for the help on this. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Posted: Fri Dec 22, 2017 10:29 am Post subject: Re: i need to change the door pins |
tb03830 wrote: |
Thank for the help on this. |
I don't remember |
