mcdragracer Samba Member
Posted: Tue Jan 17, 2017 11:38 am Post subject: Need recommendation clutch disk for sandrail |
Gonna have a 200ish HP engine in a mid engine 2 seater OG high jumper sandrail, need a rec on a clutch disk, going to be running a stg 2 kennedy plate, not looking for something radical like a 3 puck, maybe a 4 or 6 puck or something else?
I guess looking for something that works and thats not so grabby like a 3 puck and wont slip, customer will have his foot into the throttle half the time and then putts around the other half.
(dont know the gearing in the trans sorry) |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Tue Jan 17, 2017 11:49 am Post subject: Re: Need recommendation clutch disk for sandrail |
Most anything with "pucks" will be grabby. And for that light vehicle, does it really need a "stage 2" pp? That'll just make the pedal harder to push and make what ever disc you do use that much more grippy. |
maui Samba Member
Posted: Tue Jan 17, 2017 12:11 pm Post subject: Re: Need recommendation clutch disk for sandrail |
Daiken and stage 2 jus in case cuz it light weight if you get air and rev run away the ting stuyet going in gear. No miss shifts. |
Posted: Tue Jan 17, 2017 12:32 pm Post subject: Re: Need recommendation clutch disk for sandrail |
Got NOS on it, May or May not use it, reason for stg 2 and has hydraulic clutch, is the daiken the standard style clutch disk?
I had been looking at the 4 and 6 pucks, of setup was a 3 pucks and stg 4, he's just looking for a little drivability at low spds without so much grabbiness and hooks good high rpm, you know the best of both worlds 😁 |
Howard 111 Samba Member
woodsbuggy Samba Member
Joined: December 15, 2007 Posts: 210 Location: NE Indiana
Posted: Tue Jan 17, 2017 7:21 pm Post subject: Re: Need recommendation clutch disk for sandrail |
Kennedy 6 puck has worked very well for us offroad, the stock type clutch disks have a very short life with larger tires and more hp. The 6 puck is much smoother that a 4 puck.
Good Luck
Kenric _________________ The empty can rattles the most! |
Posted: Tue Jan 17, 2017 9:00 pm Post subject: Re: Need recommendation clutch disk for sandrail |
Yeah, does have big paddle tires for the sand, almost gonna steer towards a 6 or 4 pucks, I'm gonna look into that berg disk tho. |
77charger Samba Member
Posted: Wed Jan 18, 2017 7:31 pm Post subject: Re: Need recommendation clutch disk for sandrail |
Daiken or kush lock will work just fine.
Years ago on my first rail i ran a 1700 pound pp with a puck style disc it worked great but it wore a groove in the pressure plate that was kind of deep.This was with my 1776 engine.
I later switched to a standard disc and no more grooving the PP went to 1914 went to daiken same PP no issues and now a 4 seater car with paddles in glamis.Now a 2275 still using a daiken and 1700 pound plate with no issues i get 3-4 seasons out of a disc which reminds me it will prob need changing soon.But have yet to have one slip. _________________ Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine |
Tbirdusa Samba Member
Joined: November 29, 2006 Posts: 1460 Location: Kansas City, MO
Posted: Thu Jan 19, 2017 10:39 pm Post subject: Re: Need recommendation clutch disk for sandrail |
You look into the copperhead? It's damn smooth when you want it to be and a firm shifter with instant feedback to your foot. I thought it overkill but didn't want to drop the engine again so I put the copperhead in. I rally like it. My buddy's that drive all comment on smooth engagement and just feels good. Completely subjective but a lot in these cars is. _________________ Royals 2015 World Champions
Chiefs 2017 Superbowl winner
1986 Falco records Rock Me Amadeus! |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Thu Jan 19, 2017 10:46 pm Post subject: Re: Need recommendation clutch disk for sandrail |
Tbirdusa wrote: |
copperhead |
Bingo
Only thing not to like is it is a little heavier, but not as heavy as a six puck. |
Posted: Thu Jan 19, 2017 11:07 pm Post subject: Re: Need recommendation clutch disk for sandrail |
Spaced on that one, I'm gonna run that on a street turbo, but didn't think about using it in the sand. |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Fri Jan 20, 2017 12:15 am Post subject: Re: Need recommendation clutch disk for sandrail |
Same here. KEP Stage 2 & Berg Centerforce disc with 200+ HP to the wheels. Excellent both on the street and racing, and saves gearboxes! _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Posted: Fri Jan 20, 2017 3:07 am Post subject: Re: Need recommendation clutch disk for sandrail |
Center force from berg looks good, just checked out
the dual friction from CB, any thoughts on that one? |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Fri Jan 20, 2017 5:52 am Post subject: Re: Need recommendation clutch disk for sandrail |
mcdragracer wrote: |
They are both the same item. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Fri Jan 20, 2017 11:24 am Post subject: Re: Need recommendation clutch disk for sandrail |
I've got a big order the place from cb, think I'll just go
with cb's disk then. |
