bil600 Samba Member
Joined: January 11, 2017 Posts: 2 Location: Quebec, Canada
Posted: Tue Jan 17, 2017 7:47 pm Post subject: Excessive Endplay!? |
Hi there, i'm building a Karmann ghia 1968 with an AH 1600 engine in it and it's my first flat 4 engine that I have. I can move the flywheel by hand. I know it's not normal but I want to know if I change all the internal bearing this will eliminate the end play or i have to machinate the block? Thanks for your help! |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3439 Location: San Diego
Posted: Tue Jan 17, 2017 8:11 pm Post subject: Re: Excessive Endplay!? |
Yes, usually the block gets beat on the thrust and requires resurfacing. You can check the fit with a new bearing. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
you have to actually see the thrust #1 bearing and determine if it fits the case with out movement.- if no movement then re shim and see what happens. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
bil600 Samba Member
Posted: Tue Jan 17, 2017 8:37 pm Post subject: Re: Excessive Endplay!? |
Allright thank you guys, I just order new main bearing, I will stay in news with you! |
slalombuggy Samba Member
Posted: Tue Jan 17, 2017 9:30 pm Post subject: Re: Excessive Endplay!? |
I wouldn't order bearings until you can figure out what bearings are in it? Are they stock, has it been rebuilt before and thrust cut already, once? twice? Is the case savable? Pull the flywheel off and push in on the shoulder of the bearing, then push in on the pulley end of the crank. If the bearing moves the case needs cutting. I hope you can return the set you ordered if you need to.
brad |
