timichango Samba Member
Joined: April 07, 2012 Posts: 858 Location: Squamish, BC, Canada
Posted: Wed Jan 18, 2017 10:03 am Post subject: Sliding door sagging towards rear |
Quick question — in the past couple of days, for no apparent reason, my previously fine sliding door has decided to sag towards the rear of the van, and now isn't closing properly without some manual pressure applied to the rear of the door, from the outside, when closing to get it to latch.
Essentially, the sag seems to be mucking with the latch mechanism alignment.
The front roller bearings top/bottom in the upper and lower channels seems fine.
Any idea what would cause this, and how to fix it? Yes I have the Bentley, but I'm finding it challenging to decipher what's causing the issue, and therefore which adjustment to perform. Any more succinct guidance would be much appreciated.
-T _________________ . . . . . . . . . . . . . . . . . . .
Vroomhilde-San: Our 1991 Silver Vanagon Westy automatic + Subie EJ25 |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Wed Jan 18, 2017 10:19 am Post subject: Re: Sliding door sagging towards rear |
watch this..
https://www.youtube.com/watch?v=M5UrduOCJws
you don't need to remove anything if you don't want have new rollers...
at 5:32 - re-assembling the hinge
- loosen the 3 bolts
- lift the door a bit (.25"?) by using a helper hold it and tighten the 2 rear bolts.
- close the door for test... if it's OK tighten the inner bolt and you're done... otherwise adjust again...
Posted: Wed Jan 18, 2017 10:25 am Post subject: Re: Sliding door sagging towards rear |
0to60in6min wrote: |
watch this..
- close the for test... if it's OK tighten the inner bolt and you're done... otherwise adjust again... |
Awesome. It wasn't too clear that there was any room for adjustment in the hinge bolts — I was afraid it was a pretty rigid/precise fit, and that the only way to 'adjust' was to essentially replace the hinge and/or rollers. I'll give it a little tweak and see if that helps.
Thanks! _________________ . . . . . . . . . . . . . . . . . . .
Posted: Wed Jan 18, 2017 11:43 am Post subject: Re: Sliding door sagging towards rear |
Worked a charm. Fixed, and seems good as new. Thanks again! _________________ . . . . . . . . . . . . . . . . . . .
Posted: Wed Jan 18, 2017 11:49 am Post subject: Re: Sliding door sagging towards rear |
how do I know this? last week I replaced all the rollers on the sliding door... it's very quiet now... I highly recommend it since the rear vertical roller could break if it's too worn and the door will fall off ... and you don't want this to happen on a trip..
http://www.thesamba.com/vw/forum/viewtopic.php?t=615936 |
Posted: Wed Jan 18, 2017 1:03 pm Post subject: Re: Sliding door sagging towards rear |
Ack! Good to know. I reckon I'm adding "replace whole hinge assembly preemptively" to my loooong list of maintenance for the springtime.
Thanks!
