Fram Oil Filter
Jasonmorris
Jasonmorris is offline
PostPosted: Mon Feb 20, 2017 7:23 am    Post subject: Fram Oil Filter Reply with quote
My 56 has a fram oil filter mounted on the fire wall. Both the hoses were broken. There is one that goes where the oil sending unit goes and one fitting in the gen stand. Need to know if it matters which hose goes to which side of the filter housing.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Feb 20, 2017 7:34 am    Post subject: Re: Fram Oil Filter Reply with quote
Yes it matters.
Oil enters the top and exits the bottom.
Glenn
Member #1009
#BlueSquare
Jasonmorris
PostPosted: Mon Feb 20, 2017 7:51 am    Post subject: Re: Fram Oil Filter Reply with quote
So I would assume it goes from the oil press switch to the inlet. then from the bottom to the gen stand. Correct?
Mr. 010
Glenn is offline
PostPosted: Mon Feb 20, 2017 8:20 am    Post subject: Re: Fram Oil Filter Reply with quote
Correct.
Glenn
Member #1009
#BlueSquare
Jasonmorris
PostPosted: Mon Feb 20, 2017 10:20 am    Post subject: Re: Fram Oil Filter Reply with quote
While I am thinking about it. What would the oil capacity be with this filter added. DO I feel the filter up on its own?
