Yellowchev Samba Member
Posted: Thu Jan 26, 2017 1:30 pm Post subject: Rear bumper install |
Hey guys,
I've got a 70 Baja that has a newer (not sure on the year) transaxle and I have a bolt on bumper from Chirco. When I hold it up to get an idea of how it fits, it's doesn't seem to go in as far as it should. I started looking and it looks like I have some after market brace extensions to hold the transaxle? What do I need to do to properly and securely install the bumper? I'll try and post some pics. Also, bolting the top end of this bumper into the fire wall is giving me some heartburn. Doesn't seem structurally sound. What are your thoughts?
cbeck Samba Member
Posted: Thu Jan 26, 2017 4:30 pm Post subject: Re: Rear bumper install |
I would not feel comfortable with that bumper bolted to unsupported sheet metal. Been rear ended in acvws twice. One was a similar bumper but the top tubes bolted onto the top shock mounts. That one bent up and took out the push rods and tubes on one side. The next time was in a garden variety rail. Cut that in half and am still fabricating. Don't under estimate the force it could see. |
Dark Earth Samba Member
Posted: Thu Jan 26, 2017 4:38 pm Post subject: Re: Rear bumper install |
I plan on installing this Empi 9543 transmission mount, and
these rhino mounts.
The lower bumper mount will use the bolt that attaches the transmission mount to the frame horns. I'll probably have to modify the transmission mount to fit.
Something like this ...
My upper mount is a "shock mount" style rather than a "firewall mount" style.
_________________ My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ |
Posted: Thu Jan 26, 2017 4:42 pm Post subject: Re: Rear bumper install |
cbeck wrote: |
I agree. My next option was the shock mount version like you suggested but even then from what you're saying it doesn't strong enough... bummer. |
Posted: Thu Jan 26, 2017 4:46 pm Post subject: Re: Rear bumper install |
Dark Earth wrote: |
I plan on installing this Empi 9543 transmission mount, and...
these rhino mounts...
Something like this...
My upper mount is a "shock mount" style rather than a "firewall mount" style. |
Hmmm I'm curious to see how that turns out?! Post pics?! |
Posted: Thu Jan 26, 2017 4:51 pm Post subject: Re: Rear bumper install |
Yellowchev wrote: |
My build is going really sloooooooooooooooooooooow, but I do document everything with pictures along the way. I'm a long way from mounting bumpers _________________ My Build: '69 Baja - Dark Earth Version
cbeck Samba Member
Posted: Fri Jan 27, 2017 4:37 am Post subject: Re: Rear bumper install |
Stay tuned to my build thread, should be starting my engine cage in the next couple of weeks. Started this build a year ago, it has also been a little slow. |
Posted: Fri Jan 27, 2017 10:23 am Post subject: Re: Rear bumper install |
Hey I'm a little new to the samba, can you post or guide me to both of your build links? |
cbeck Samba Member
Posted: Fri Jan 27, 2017 5:52 pm Post subject: Re: Rear bumper install |
So soon? |
Posted: Fri Jan 27, 2017 7:35 pm Post subject: Re: Rear bumper install |
?? Haha I meant if you have a build thread where could I find it so I can follow it? |
cbeck Samba Member
Posted: Sat Jan 28, 2017 4:14 am Post subject: Re: Rear bumper install |
It is titled so soon? It is near the top of this off road forum. Start on page 1 and see what a drunk in a 4x4 ram truck did to my rail. It had less than 2k miles on it since the last redo. |
Posted: Sun Jan 29, 2017 8:45 am Post subject: Re: Rear bumper install |
cbeck wrote: |
sweet!! I'll check it out thanks!! |
weasel_ugs Samba Member
Joined: March 16, 2012 Posts: 721 Location: Prescott Valley,Az.
Posted: Sun Jan 29, 2017 1:37 pm Post subject: Re: Rear bumper install |
As mentioned above I would never use a bumper mounted to the firewall. Mine was mounted to the upper shock mount, I was rear ended twice and the chrome baja bumper held up both times.
As for you lower mounting point the trans strap kit thats installed on there makes it so you can get to the lower bolt to attatch your brackets. You will have to fab something up so it will all work together. |
Posted: Mon Jan 30, 2017 5:48 am Post subject: Re: Rear bumper install |
weasel_ugs wrote: |
Awesome, thanks I am probably going to replace the strap with a better one anyhow (empi #9507) and should have a better setup to then attach bumper. I'm working on something where I can mount the upper portion to some horizontal steel that angles down back into the frame. Appreciated all the help and comments. |
Posted: Mon Jan 30, 2017 5:52 am Post subject: Re: Rear bumper install |
Does anyone have pics or could guide me to pics of what the bottom two mounts should look like? I'm lacking a visual on some of the instruction. In my mind it just inserts into the end of the pan where my strap transaxle extensions are. I'd like though to see what's correct and follow that as much as I can. |
Posted: Mon Jan 30, 2017 7:29 am Post subject: Re: Rear bumper install |
Here's a couple pics ...
The pic I posted above shows how the lower mount bolts to the transmission mount / frame horn.
I would also like to point out that a solid transmission mount will transmit A LOT of noise through the car since there is nothing to insulate the transmission from the frame. That's why the car originally came with rubber mounts. As a compromise, I plan on installing the rhino mounts to get a little more support without all the additional noise of a solid transmission mount. _________________ My Build: '69 Baja - Dark Earth Version
Posted: Mon Jan 30, 2017 8:06 am Post subject: Re: Rear bumper install |
Here's what my car looked like underneath when I first brought it home. I am getting a different transmission mount (empi #9543) and doing away with the red urethane mounts in favor of the rhino mounts. I think I'll have to grind away some of the material on the new transmission mount so the lower bumper brackets can hang down freely.
Posted: Mon Jan 30, 2017 8:43 am Post subject: Re: Rear bumper install |
This is perfect guys!! Thanks a ton!! |
cbeck Samba Member
Posted: Sun Feb 05, 2017 3:29 pm Post subject: Re: Rear bumper install |
Found a couple of pics from the 80's of my 64 1/2. It took out the right side exhaust. exhaust studs. and push rods and tubes. This one was a animal and still my favorite
dustymojave Samba Member
Posted: Tue Feb 07, 2017 9:11 pm Post subject: Re: Rear bumper install |
I'm always hearing from guys with Baja Bugs and street driven rails that they don't need a rear bumper for the street. I say it's needed a hell of a lot more for the street than for the dirt. _________________ Richard
SoCalBajas Member
