Sloppy Samba Member
Joined: January 30, 2017 Posts: 1 Location: California
Posted: Mon Jan 30, 2017 11:23 pm Post subject: VW Buggy VIN? |
I recently purchased a 1959 VW fiberglass buggy. The previous owners title and registration called it a 1959 VW. It's VIN I found was located on the center pan right behind the emergency brake. The VIN was 2403636. That is what the previous owners VIN was, and that what is now on my title and registration.
Today I was working on it, I found some papers from owner who owned the buggy BEFORE the guy I bought it from. Well those papers listed the VIN as a 1966 VW beetle with a VIN of DRF 104477. I inspected further and found a small rectangular plate welded near the clutch pedal along the left wall by my foot. The plate had DRF 104477.
How are the previous two owners VIN's different, and what VIN should I use? What do I even call the fiberglass buggy for insurance purposes? |
AMAC1680 Samba Member
Joined: April 09, 2015 Posts: 300 Location: Jacksonville Fl/Mantoloking NJ
Posted: Tue Jan 31, 2017 3:19 am Post subject: Re: VW BUGGY VIN? |
I can't help you with the vin but others here far more knowledgeable than I will.
What I do know is don't tell the insurance co that it's a "dune buggy". That almost always turns out bad.
AMAC _________________ www.SEGS4VETS.org |
vponder Samba Member
Posted: Tue Jan 31, 2017 4:58 am Post subject: Re: VW BUGGY VIN? |
That tag you found is more than likely a VIN issued when the buggy was first built and put on the road. My neighbor has a Manx body when we were taking it off the old chassie we found a tag under the right front fender that was screwed in the fiberglass, it was from the DMV in PA it had a short number on it. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76897 Location: Sneaking up behind you
Posted: Tue Jan 31, 2017 5:02 am Post subject: Re: VW BUGGY VIN? |
AMAC1680 wrote: |
AMAC |
If you ever need to file a claim, they can deny it due to your lie of omission. _________________ Glenn
Member #1009
#BlueSquare |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20377 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Jan 31, 2017 5:50 am Post subject: Re: VW BUGGY VIN? |
Technically by Calif DMV it is not a 1959 VW it is a SPCN or SPecial CoNstruction by interpretation of California DMV code... And the 1966 title is what it probably should be registered under and that was when buggy was actually built as kit car...
Only DMV can clarify the dilemma you have.... BUT if you question it with wrong DMV clerk you will open up a whole can of worms to get proper title... IT would be my guess that if previous owner had it register with the VW VIN for quite a few years (10 I believe) the Calif DMV title and VIN may have dropped out of the computer and may not be valid....
IF you misrepresent the buggy which is actually a "kit car" by definition not a VW beetle to your insurance as others have said you might lose your coverage in case of a incident becasue you misrepresented the vehicle to them and they will base their rejection of claim and cancellation of your insurance because you intentionally committed fraud by misrepresentation..
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Tue Jan 31, 2017 9:16 am Post subject: Re: VW Buggy VIN? |
I'd think the one stamped by VW on the tunnel behind brake handle which matches current title is one to go with. The one welded on by a PO is bogus. Your chassis was most likely shortened. Perhaps the front came from a different year than the rear section. I too would avoid dune buggy and go with kit car. Since in Calif you can apply for the Special Construction but aren't there only 500 issued per year? _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
HeidelbergJohn4.0 Samba Member
Joined: March 01, 2004 Posts: 1199 Location: Havre de Grace, MD
Posted: Wed Feb 01, 2017 10:56 am Post subject: Re: VW Buggy VIN? |
In a way it is similar to what I have with my Fire Aero, though being a bike based kit car, I actually have two titles. I have the valid title to the Honda V45, however I also have a valid title which corresponds to the Special construction VIN assigned to the completed vehicle. Missouri would only title it as a special construction vehicle, however VA and Maryland titled it as a motorcycle on the valid OEM VIN. both states just rolled their eyes on the special construction and said basically, you don't want to go there.
I'd go with whatever you have the up to date title and registration on and be honest with the insurance company regardless of how it's titled if you put it on the road. _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.) |
Posted: Wed Feb 01, 2017 12:20 pm Post subject: Re: VW Buggy VIN? |
Wolfgangdieter wrote: |
I'd think the one stamped by VW on the tunnel behind brake handle which matches current title is one to go with. The one welded on by a PO is bogus. Your chassis was most likely shortened. Perhaps the front came from a different year than the rear section. I too would avoid dune buggy and go with kit car. Since in Calif you can apply for the Special Construction but aren't there only 500 issued per year? |
Not necessarily bogus, at one time it may have been valid, IF there is paperwork to support it...
California does have authority to issue a VIN for any kit car in California...
Posted: Sat Feb 04, 2017 2:32 pm Post subject: Re: VW BUGGY VIN? |
Glenn wrote: |
AMAC1680 wrote: |
AMAC |
If you ever need to file a claim, they can deny it due to your lie of omission. |
I didn't say register it as a beetle.
I said don't call it a dune buggy because as we know many will not insure based on that description. Kit car works mich better.
I agree anything else is fraud.
