driftman11 Samba Member
Joined: August 01, 2012 Posts: 141 Location: little rock,ar
Posted: Sun Feb 05, 2017 9:10 pm Post subject: Body to Shock tower bolt size/ replacement? |
Alright I am putting my 74 body back on the pan and realized I'm not sure which bolts bolt the rear shock tower to the body with the rubber pad under them? A place to buy these bolts would be very appreciated as well. |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Mon Feb 06, 2017 7:57 am Post subject: Re: Body to Shock tower bolt size/ replacement? |
Asked him already. He didn't have them. I haven't been able to find a bolt that is for this particular purpose yet on any of the VW sites. I'm told its not a normal bolt so I was hoping to get an image of it so I knew for sure what it looked like to maybe find the bolt off another application or something that will work. |
seilerj Samba Member
Joined: February 03, 2013 Posts: 66 Location: Illinois
Posted: Mon Feb 06, 2017 8:34 am Post subject: Re: Body to Shock tower bolt size/ replacement? |
GI Joe Samba Member
Posted: Mon Feb 06, 2017 8:36 am Post subject: Re: Body to Shock tower bolt size/ replacement? |
I hope these help |
Posted: Mon Feb 06, 2017 8:52 am Post subject: Re: Body to Shock tower bolt size/ replacement? |
alrighty! that photo helps a lot. I believe I found the bolts that are used but I didn't have any spacers with them. HMMMM.. where does the spacer actually go? does it fit in the bolt holes on the rubber spacers and thru the tower? Like to keep them all together or how? |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Mon Feb 06, 2017 9:24 am Post subject: Re: Body to Shock tower bolt size/ replacement? |
The bolts are 10 mm but they have a 15 mm head. I have never found these. |
Posted: Mon Feb 06, 2017 9:28 am Post subject: Re: Body to Shock tower bolt size/ replacement? |
You could use socket head or allen head bolts. |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Mon Feb 06, 2017 10:44 am Post subject: Re: Body to Shock tower bolt size/ replacement? |
The spacer fits inside the rubber. I have that bolt new if you need one. The bolt is a JIS spec. metric bolt. Much like the smaller head exhaust nuts that people use. Same spec. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Mon Feb 06, 2017 3:44 pm Post subject: Re: Body to Shock tower bolt size/ replacement? |
JIS is Japanese Industrial Standard.
Lots of good hardware stores sell JIS metric hardware. I think an M10 would have a 14 or 15 mm head (in JIS form).
As a last resort, order JIS hardware from BelMetric.
Good luck, Mondshine |
Posted: Tue Feb 07, 2017 9:00 am Post subject: Re: Body to Shock tower bolt size/ replacement? |
I tried BelMetric they only have small wrench size in fine tread. |
Posted: Tue Feb 07, 2017 11:29 am Post subject: Re: Body to Shock tower bolt size/ replacement? |
Well on a good note, after doing a clean up in the garage, I was able to find my old bolts. They didn't have the spacers but I have the bolts so atleast I won't have to hunt down this long lost bolt lol |
Posted: Tue Feb 07, 2017 12:01 pm Post subject: Re: Body to Shock tower bolt size/ replacement? |
They are not very easy to find. The closest one I was able to find, was one that didn't have the shoulder, was threaded all the way to the head of the bolt. It has the proper 14mm head and that was the hard part. We don't have hardware stores anymore just Home Depot. |
ente_kaefer Samba Member
Joined: August 22, 2013 Posts: 242 Location: St Louis, MO
Posted: Tue Feb 07, 2017 1:18 pm Post subject: Re: Body to Shock tower bolt size/ replacement? |
Al Capulco wrote: |
If you have an Ace Hardware near by, try them, I have been able to locate all of the metric sized bolts I have needed for my vehicle from them. |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Sat Feb 11, 2017 3:45 pm Post subject: Re: Body to Shock tower bolt size/ replacement? |
I do have some spacer sleeves... _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
