dm Samba Member
Posted: Thu Feb 09, 2017 3:52 pm Post subject: How much to remove surface rust before por15 |
So if my pans or another part of the body just has surface rust, how much should i work to remove before adding phosphoric acid and the por15 or other treatment? Do i labor for hours and try to sand and remove all tiny rust spots or just sand what essentially what i can then add the phosphoric acid and then por 15 it?
Also, my understanding is por15 is not very good if you are going to paint the metal. If so, whats the best thing to use if i want to paint?
Thanks! |
catahoula lou Samba Member
Joined: August 30, 2008 Posts: 594 Location: south of Silver Springs, NV
Posted: Thu Feb 09, 2017 4:28 pm Post subject: Re: How much to remove surface rust before por15 |
Just went through this with my 59 ragtop.
I would wire-brush the heavy rust and then spray with the phosphoric acid, keeping it wet for at least 30 minutes or so. Rinse off with fresh water, towel dry, then spray with acetone to carry away remaining water. Repeat, as needed.
Let dry overnight, then put on POR-15. I used the glossy black POR-15, as it's much easier to work with.
If you're spraying the acid anywhere that it can drift onto paint, tape/cover it, as it will slightly bleach the paint (protects against acetone overspray/drift as well).
I did two coats of POR-15 and looks good 1.75 years later. Transfer POR-15 into a mason jar before you begin, as the can/lid is not really designed for multiple openings/closings and will let the contents dry out after you've bent them up...
Best,
Thom _________________ 1 great wife
2 Catahoula Leopard Dogs (Mahogany Star and Spartan) - RIP Lucy, Braveheart, & Dusty!
1 1959 mango green Ragtop Bug (the "Mango")
1 1958 pantina red Lowlight Ghia (the "Chili Pepper")
Still looking for:
(1) My Dad's 1955 356 (he raced it amateur-class at Riverside and other courses during 1950s),
(2) My parent's black 1955 hardtop bug (CA license plate FWC 201 or FWG 201), and
(3) My parent's agave green 1957 ragtop bug (CA license plate LFK 734). |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Mon Feb 13, 2017 12:55 pm Post subject: Re: How much to remove surface rust before por15 |
dm wrote: |
Thanks! |
Maybe its just your wording. I can see using POR 15 or a similar product on the pans. I would not use it on any body parts that are exposed or will be painted.
You also may want to consider a rust converter product before final treatment. _________________ Ghia Owner Emeritus |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2874 Location: Auckland, New Zealand
Posted: Mon Feb 13, 2017 2:11 pm Post subject: Re: How much to remove surface rust before por15 |
NOVA Airhead wrote: |
dm wrote: |
Thanks! |
You also may want to consider a rust converter product before final treatment. |
My experience with POR15 is that it needs a slightly oxidised surface to adhere to the metal. Someone - I think it was Dorian from Belgium - suggested wetting the surface to be treated and letting it react to the oxygen in the air before applying the POR15.
Where I used a rust converter, the POR15 didn't adhere well and in places flaked off. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Mon Feb 13, 2017 3:49 pm Post subject: Re: How much to remove surface rust before por15 |
Where I used a rust converter, the POR15 didn't adhere well and in places flaked off.[/quote]
Not sure about this - the POR15 metal ready preparation product removes surface oxidation _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
dm Samba Member
Posted: Sat Feb 18, 2017 12:44 am Post subject: Re: How much to remove surface rust before por15 |
Thanks for the responses. I pretty much wire brushed and added phosphic acid, then the por 15 the next day for the pans.
I was asking about how to treat rust for metal that will be repainted? Unfortunately, welding isnt an option for me at this point so I do want to do as good a job as possible when there is surface rust and some pitting.
Thanks! |
Starbucket Samba Member
Posted: Sun Feb 19, 2017 2:17 pm Post subject: Re: How much to remove surface rust before por15 |
If your pans are thin from rust and you are treating them inside the car, laying some thin fiberglass cloth over the 1st coat of por15 and follow with two more coats of por15 will add a lot of strength and keep you from falling through while driving. |
Posted: Sun Feb 19, 2017 2:22 pm Post subject: Re: How much to remove surface rust before por15 |
dm wrote: |
Thanks
Buy some metal prep from any paint supply store and brush it on before painting, it will turn any surface rust into black primer in a few hours and the paint primer will bond to it. |
dm Samba Member
Posted: Mon Feb 20, 2017 5:01 pm Post subject: Re: How much to remove surface rust before por15 |
Ok thanks! Is that just like phosphoric acid or different? |
Posted: Tue Feb 21, 2017 8:40 am Post subject: Re: How much to remove surface rust before por15 |
It's different. It's what paint shops put on bare metal before primer. |
dm Samba Member
Posted: Tue Feb 21, 2017 9:06 am Post subject: Re: How much to remove surface rust before por15 |
Great! Thanks! |
c21darrel Samba Member
