Jasontwl Samba Member
Posted: Fri Feb 10, 2017 12:13 pm Post subject: VW1915 How much HP? |
I am buying a new rail with a VW 1915 with dual 44weber carbs, whats the estimates HP on this engine? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Fri Feb 10, 2017 1:43 pm Post subject: Re: VW1915 How much HP? |
75hp if it is stock with the exception of parts pistons.
275hp if it has a turbo, electronic fuel injection, computerized engine management and runs on alcohol.
No one can possible give a realistic estimate only knowing the displacement and carbs. Heads, cam, compression, ignition, exhaust all are needed info. _________________ Glenn
Member #1009
#BlueSquare |
Douglas A Samba Member
Posted: Fri Feb 10, 2017 2:01 pm Post subject: Re: VW1915 How much HP? |
Jasontwl wrote: |
Very little with today
standards when some new 4 cylinders our pumping out 260 HP stock! |
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1059 Location: St. Louis
Posted: Fri Feb 10, 2017 2:11 pm Post subject: Re: VW1915 How much HP? |
If it's jetted decently/semi-poorly and has stock dual port heads it might make 75-80 hp.
Lets say it has some generic 40x35 valve heads on there, a counterweighted crank, 110 cam, and is jetted/timed well and nothing else much special, probably 100 HP.
That should get you in the ballpark. Should be plenty fun. When I had my rail running I had similar to the second option above, and it was not boring. Single 44 IDF on mine, stupid 009 distributor and it was still fun. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
