2748photo Samba Member
Posted: Wed Feb 15, 2017 8:10 pm Post subject: Running rough and loss of power |
My son's square back started running a bit rough the other day and has the sound and power that feels like it is running on 2 or 3 cylinders all of the sudden. It is a 1600 in 1966 6V car. The car starts and idles. The idle is a bit low. When you try to drive it you barely have enough power to get into 2nd gear and it runs out with a heavy miss.
Where do I start on finding what is the problem? Spark or Fuel first. I can pull the plugs and check spark. How do I best test the fuel delivery?
Thanks for your help. |
KahunaKombi Samba Member
Joined: December 17, 2016 Posts: 97 Location: Bracken Ridge Qld Australia
Posted: Thu Feb 16, 2017 12:11 am Post subject: Re: Running rough and loss of power |
Check spark plugs or if they haven't been replaced for a while then just replace them. See how it runs if if still ragged then see next.
Could be fuel filter also blocked.
Other electrical like points and/or condensor. If electrical ignition then unlikely but could be point of last resort. After that coil possibly.
If those things haven't been checked/serviced/replaced since you can't remember then a good service & replace. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Thu Feb 16, 2017 6:44 am Post subject: Re: Running rough and loss of power |
What were the circumstances leading up to this development? In other words, what happened immediately before the car started running rough.
If this happened to me out of the blue, first thing I would check is the points and timing. If the points gap closes up it can cause missing and when the gap changes it also changes the timing so that combination can make it run pretty crappy.
Of course check and make sure something stupid hasn't happened, like one of the spark plug wires coming off the plug.
You running the stock Solex dual carbs? _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Thu Feb 16, 2017 2:02 pm Post subject: Re: Running rough and loss of power |
I'd check the valve clearances, and the points first, as both will close up. Then I'd look to see if I had a clogged fuel filter. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Feb 16, 2017 4:21 pm Post subject: Re: Running rough and loss of power |
2748photo wrote: |
Did one of your throttle control rods pop off at one end? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Feb 16, 2017 9:38 pm Post subject: Re: Running rough and loss of power |
sjbartnik wrote: |
You running the stock Solex dual carbs? |
He was in the middle of driving home from school and the was accelerating from a stop and the power started to cut out. He had only been driving for 5-10 minutes from school on city streets.
Yes dual stock carbs. |
Posted: Thu Feb 16, 2017 9:40 pm Post subject: Re: Running rough and loss of power |
Bobnotch wrote: |
I'd check the valve clearances, and the points first, as both will close up. Then I'd look to see if I had a clogged fuel filter. |
Thanks. I'll take a look this weekend and let you know what happened. |
Posted: Thu Feb 16, 2017 9:41 pm Post subject: Re: Running rough and loss of power |
Tram wrote: |
2748photo wrote: |
Did one of your throttle control rods pop off at one end? |
That's an easy one that I will check out first. Thanks for your help. |
