germanx Samba Member
Posted: Fri Feb 17, 2017 2:49 am Post subject: Roll bar in the make |
Hi there,
Just wanted to share my rollbar project which finally has arrived at a state where I can show some progress.
The reason for a new rollbar was the old one was too large so I could not fit my hard top. After some years of planning, measuring and pausing, I finally have arrived at this stage:
First the original rollbar that came with the car, slightly too high and wide on top:
I contacted a pipe bending shop which normally does work for power plant pipelines, and they offered to bend my two rollbars over the weekend.
I provided some drawings with measurements taken at the buggy body:
rear:
front:
and when I received the parts, I just had to cut to final length.
And here the rear hoop (to the right behind the car, the original rollbar):
In the front, I cut out the dashboard to ensure parallel and tight fit with the window frame so that from an side angle the rollbar does not disturb the lines of the car.
(Sorry but I cannot figure why the foto shows in 90 DEG rotation after uploading....)
I decided to connect both bars with a side structure of rectangle profile steel which sits inside the body. It is connected to the chassis with the body/ chassis screws.
I did not want to separate and lift the dashboard / hood from the body in order to fit the cage-like structure in one piece, so I planned and fabricated it in two parts:
The front rollbar with the major part of the side structure, and the rear bar with a small part of it.
The connection of both sections is done with self made solid steel connectors. The connectors are slotted on the backside so that I can slide in a self securing nut which cannot rotate.
Hope this picture gives you an idea:
I am not done yet. It looks much more straight forward than it actually was, because the side profile of the body is not a plane. I had to bend the rectangular sections to follow the body lines.
And for those of you who know that welding will slightly deform the structure, you might have an idea what it took to readjust and ensure the two pieces fit together to each other, and the whole construction still fits to the car after having been welded.
The major fitting work is done, just need to add some mounts for the rear mirror, the gas dampers and the lock which will hold the roof tight when closed.
I have planned to paint the lower part (the rectangular connecting rods) in body color to keep them visually morphed into the side wall, and the rollbars will get a glossy alloy silver color.
What I have seen and I like is may be to add a flap or door to the side structure and use one or more compartments (1.5" deep) to store fuses, tools, safety vest, emergency knife, light bulbs and similar small stuff...
And some comment to the safety aspect: Yes, my setup is still a mouse trap setup. The front roll bar is better than none, and in combination with the side curtain structure it is better than just the window frame alone.
But any other layout of the roll cage (connecting rod on top, rear tubes down to the frame) will definitely kill the classic look of the car. And this is what I appreciate most... _________________ '73 Beach Buggy
'66 T1 Deluxe |
A E Numan Samba Member
Joined: March 12, 2006 Posts: 238 Location: Portland Oregon
Posted: Fri Feb 17, 2017 9:50 am Post subject: Re: Roll bar in the make |
Wow what a nice looking job! That's going to add a lot of strength to your buggy. |
joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Fri Feb 17, 2017 6:45 pm Post subject: Re: Roll bar in the make |
I like your side structure, should add safety and strength. You might find that you need to connect the 2 hoops together at the top. On my rollbar, until I tied them together at the top, the front hoop would flex enough to rattle against the dash/windshield area. Also, without the 2 hoops being connected at the top, they could collapse/bend in case of a rollover. |
Posted: Tue May 23, 2017 11:20 pm Post subject: Re: Roll bar in the make |
Ok, some update and sorry for the bad pic quality. Here is the rollbar finally mounted in the car.
I painted the lower end sitting level with the body in body color, Porsche Sepia Brown from 1971.
The hoops are painted in a BMW Silver metallic covered with 2k Clear coat.
Oh, and I just noticed in the picture German waste bins for bio-waste have the same deck lid color than our buggy...
'66 T1 Deluxe |
YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Wed May 24, 2017 3:53 am Post subject: Re: Roll bar in the make |
Nice work.
Mine has no room for side curtain bars, the seats are up against the body.
Not too many buggies in Germany, any problems getting TUeV done? _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
Posted: Wed May 24, 2017 5:01 am Post subject: Re: Roll bar in the make |
Hi und Danke!
I bought our Buggy with TÜV and Oldtimer registration. Since then no big issues with the check. But it becomes more and more challenging. Fingers crossed I have to go this year...
I had no issue fitting the cage between body and seat back. I had replaced the already small 914 seats (Kamei) with a set of even smaller low bucket seats. I don't know the car type or brand. They are so small that I just fit flush in the seat without room to move sideways (Jeans size 32).
Seems I got lucky with the swap because I did not check this in detail planning the cage. The cage reduces the internal width by 3 1/2 inches (~85 mm). They just touch the side of the seat.
I think it is even more important to check the space for your left leg and foot. Many people lean the knee to the left to not touch the steering wheel during shifting. My boss is extra long (self made) to push the steering wheel towards the rear and beyond the knee line, so I don't have this problem...
Have fun! _________________ '73 Beach Buggy
'66 T1 Deluxe |
