xzener Samba Member
Posted: Fri Feb 17, 2017 9:03 am Post subject: Reshape Fender Lip |
Hello guys,
Finishing up the body work on my 68 KG. I've saved the worst for last. The fender lips are in bad shape. Mainly the front passenger fender. Is there a trick to reshaping them and having a nice clean round finished look?
I was pondering using a 1/2" steel pipe. Attempting to hold it in place while I wack at it with a hammer.
Thoughts/suggestions??
Thanks! _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
c21darrel Samba Member
xzener Samba Member
Posted: Fri Feb 17, 2017 4:06 pm Post subject: Re: Reshape Fender Lip |
Yes, it's still lumpy. I've managed to flatten the forward most section. Then, as it goes up towards the top, it curves. I borrowed a bunch of tools from my buddy. It's shaping up... Better than it was. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Sun Feb 19, 2017 9:43 am Post subject: Re: Reshape Fender Lip |
There are replacement panels for the wheel wells, if you find too much rust and filler. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
xzener Samba Member
Posted: Sun Feb 19, 2017 10:15 am Post subject: Re: Reshape Fender Lip |
The shape is fine, no rust either. The problem is, the front clip was replaced with an early 70's. Their for, the filler is to shape where the late style blinker hole was. I've managed to shape the lip back to where it should be... Now I have ripples in the lip to deal with. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
