Tkisner Samba Member
Posted: Sat Feb 18, 2017 9:55 am Post subject: Throttle Cable Headache |
Long story short replacing broken cable. New Cable tied to old cable came off. Old cable broke again while being pulled through the back and is now stuck below the flexible guide which is currently off. I tried to push to old cable through with the new cable, but the new cable wont go more than a foot in from the front or the back. I tried to clean it out by spraying a ton of WD-40 into the guide tube, and by ramming a metal coat hanger in and out to try and loosen any crud up. Still not progress made whatsoever. Has anyone been in this situation before? Im strongly contemplating just cutting large chunks of the guide out, running the cable, through all the pieces then putting it back together with something like fuel line and clamps. Any advice would be a huge help. Thanks |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Sat Feb 18, 2017 11:12 am Post subject: Re: Throttle Cable Headache |
I once had a heater cable jammed in the tube. Turned out that someone had been doing some welding near the tube and accidentally touched it. I cut out that section of tube. Less than 2 inches and after removing the cable I spliced in a section of hard plastic tubing. It worked. My luck was finding the weld mark. In your case things will be tougher. So how did this happen? Has the bus been parked a long time? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Mon Feb 20, 2017 7:58 am Post subject: Re: Throttle Cable Headache |
aeromech wrote: |
I once had a heater cable jammed in the tube. Turned out that someone had been doing some welding near the tube and accidentally touched it. I cut out that section of tube. Less than 2 inches and after removing the cable I spliced in a section of hard plastic tubing. It worked. My luck was finding the weld mark. In your case things will be tougher. So how did this happen? Has the bus been parked a long time? |
The movement of the throttle cable was always super jerky. I went to put in the Butty bits conversion for the throttle pedal. Everything went smooth until I want to connect the cable to the engine. At that point it was probably like 3 inches too short, and I noticed it had been spliced together previously. So I started pulling out that cable for a new and headache and breakage ensued. |
Posted: Mon Feb 20, 2017 9:12 am Post subject: Re: Throttle Cable Headache |
If the cable was spliced, did you jam the splice in the tube when removing? Pics of your engine might help. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Mon Feb 20, 2017 11:57 am Post subject: Re: Throttle Cable Headache |
What year bus? Where are you located? You know, these pieces of info can be put in your signature and it always helps us when people ask questions. Hell, for all I know you might live down the street from me.
1) Start from the front of the tube near the front beam. Slide something aft in the tube to measure how far the blockage is.
2) Do the same from the rear going forward.
3) With this info you might be able to find on the tube where the blockage is.
4) I own rifles and when I clean the barrels I use a stiff rod. Maybe you could use something a bit smaller diameter than the tube but stiff and try and ram it through the tube?
Pictures and more info on your bus and its condition would help. Why did someone feel it necessary to splice onto the cable? If it's stock then a new stock cable would have been a better solution. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
