aa390392 Samba Member
Posted: Sun Feb 19, 2017 9:24 am Post subject: Wooden gates. |
A DOKA in the classifieds has wooden gates, say there OG, has anyone every seen them b4 ? As original equipment?
Cheers
Thomas _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Lind Samba Member
Joined: November 06, 2000 Posts: 9916 Location: idaho
Posted: Sun Feb 19, 2017 9:36 am Post subject: Re: Wooden gates. |
Westfalia widebed singlecabs had wood in their gates.
The truck in the classifieds has some custom owner built gates, not VW factory items.
Westfalia widebed:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=355266
_________________ .
Wanted:
Posted: Sun Feb 19, 2017 10:04 am Post subject: Re: Wooden gates. |
Yes I concur with you, but I thought by chance it Perhaps was one more thing, I didnt know.
55 ragtop
56 delux sedan
56 Kabriolet |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Norfolk Autowerk Samba Member
Posted: Wed Feb 22, 2017 1:21 pm Post subject: Re: Wooden gates. |
its cool there is a thread about my bus....
The gates have been on there since before it was sold ie: from the dealer, they have a padron number stamped in the wood which matches the original documents which I have, obviously the dealer had them built by a local coachbuilder and fitted to the doka before it was sold. They are very well built and are very unique. |
Clara Samba Member
Posted: Wed Feb 22, 2017 2:23 pm Post subject: Re: Wooden gates. |
cookingphat wrote: |
A few questions...
What is a padron number? Is that another term for VIN?
How does this number prove these were on the truck when sold new?
And how does that connect to the M-code 710?
When did you find that definition for M-710?
I could make some wooden gates, and stamp a trucks VIN on them, but that doesn't prove they are original to the truck. Give us a bit more info here.
If a dealer had the gates made, it would not have special gates on the M-code plate.
If they were planning on installing special gates, I'd expect them to order it without gates, Mcode 118.
Maybe a PO just wanted wood gates, or the gates got damaged and someone had these made instead? I've seen a number of custom gates, some very well made. Some were not. Unless you have something showing they were on there when new, that would be the easiest explanation. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Thu Feb 23, 2017 5:08 am Post subject: Re: Wooden gates. |
The inside of the gates appears to be painted to match the exterior and the patina appears to match. I would only question if the interior of the gates was painted why isn't the exterior?
There appears to be a rot hole on the passenger side front/bottom of the gate. That doesn't happen overnight. The gates have been on there for awhile, if not original.
If M 710 is as yet unverified, what documentation does the current owner have that M 710 applies to the gates?
Perhaps padron number is meant to be pattern number ie M code?
The seller states that he has documentation to back up his claim. He should provide it, it would also help with the sale of his truck. Those of us who are interested in VW history and variations, would be grateful for the historical input. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
tifawinner Samba Member
Posted: Thu Feb 23, 2017 2:07 pm Post subject: Re: Wooden gates. |
Hello all, i am the guy who found this Vw after being stored for more than 30 years.
I am a Vw hunter from Uruguay.
Padron number is assigned by the Department of Vehicles to a car when it is first registered. In some cases they used to stamp it on cars when they couldn't find a Vin number (mostly because they didnt know where to look).
All of the double cabs that i have seen with custom gates in Uruguay have m code 710.
This one in particular is the first wooden gates i see and i was impressed when i saw the Padron stamped on it.
There were at least 3 types of custom gates for Single cab and double cab, metal and wooden and they were fitted before they were sold for the following reason.
In Uruguay there used to be a program to encourage Uruguayan economy and labour that would exempt some taxes to cars that were finished to build in Uruguay. This was also made to other cars not just Vw.
Regards
Tifa |
Posted: Thu Feb 23, 2017 6:14 pm Post subject: Re: Wooden gates. |
Thanks for the added information Tifa. Why were you impressed by the Padron number? _________________ Roads Scholar &
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu Feb 23, 2017 7:18 pm Post subject: Re: Wooden gates. |
perhaps for the same reason i would be impressed if i saw my first crewcab with wooden gates on it, and instead of chalking it up to being something homebuilt i find the vin number stamped into it.... _________________ regards
Uli
Posted: Thu Feb 23, 2017 11:10 pm Post subject: Re: Wooden gates. |
Hello.
It is the first time i see Padron number stamped on the gates. Normally it would be stamped inside the cabin.
Tifa |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Feb 23, 2017 11:26 pm Post subject: Re: Wooden gates. |
Interesting, so this number is stamped by some official government inspector type in Uruguay?, is the stamp some sort of special font or somehow hard to forge?, or is it something anyone with a stamp kit could add to a part to make it look legit?
Those are definitely not your normal wooden gates, the local completion to dodge taxes story makes sense, but is there any documentation to back it up? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Clara Samba Member
Posted: Fri Feb 24, 2017 9:22 am Post subject: Re: Wooden gates. |
tifawinner wrote: |
Regards
Tifa |
Interesting! Do you have more pics of custom gates? Do all the Uruguay trucks have custom gates? I had heard of some countries having locally made seats for the same reason. But I had not heard of this. Please share whatever documentation you have.
M710 is listed on the samba here: http://www.thesamba.com/vw/archives/info/mcodest2.php
as Custom bed wall for Double Cab?
also as "Conti"-tires 185R14
I see that Everett just added ' Custom gates for VW Trucks?
(Possibly locally made to support the local economy)'
710 is one of the M-codes that is not listed well in the source documents... such as the front of the Parts List. Some codes had different meanings at different times, which can make it confusing. The unlisted M-codes tend to be in the 700s
It would make sense to me that if the country had a program of locally manufactured gates, wouldn't they just order them w/o gates? It would save 140DM, according to Coachwork Variations.
Did they use the normal VW gate latches? _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Fri Feb 24, 2017 10:44 am Post subject: Re: Wooden gates. |
in the 80s people would import Porsche 924 and 944 with the big glass hatch to Finnland, converted to "trucks" by removing the hatch. That way they did not have to pay the "luxury tax" which effectively doubled the price... _________________ regards
Uli
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Fri Feb 24, 2017 11:34 am Post subject: Re: Wooden gates. |
Clara wrote: |
wouldn't they just order them w/o gates? It would save 140DM, according to Coachwork Variations |
I guess if they shipped lots of them to specific countries with a particular feature, it would make sense to have a dedicated code. A bit like the 'for US market' codes for headlights, speedo and glass etc? _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Fri Feb 24, 2017 11:56 am Post subject: Re: Wooden gates. |
Perhaps maybe the owner just wanted a woody
Sorry couldnt resist
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Sat Feb 25, 2017 1:29 am Post subject: Re: Wooden gates. |
Posted: Sat Feb 25, 2017 1:39 am Post subject: Re: Wooden gates. |
Padron number..
Notice the painted insides same patina as the rest, dove blue detail on the outer in the recess.
Sides are fixed, tailgate drops on 3 big hinges. |
Posted: Sat Feb 25, 2017 1:43 am Post subject: Re: Wooden gates. |
Posted: Sat Feb 25, 2017 1:50 am Post subject: Re: Wooden gates. |
Hello
Not all but the majority of the pickups had custom gates. I attach pics of different models that i have seen.
This is me pulling the Dove blue doka out of the barn, such an exiting day.
This is some old literature to show cars imported as cabin and chassis to be finished to build by Uruguayan hands. Couldn't find Vw but I will keep on searching.
The padron number was stamped with hand tools by an inspector. Not all of the cars had it stamped but all of the cars had a Padron number on papers. I never heard of someone faking a padron stamp and the one in this truck looks authentic.
Regards
Tifa |
