1967Ghia Samba Member
Joined: September 29, 2015 Posts: 126 Location: Toronto, Canada
Posted: Sun Feb 19, 2017 6:25 pm Post subject: Rear hood Latch Part... pic??? where to buy? |
It's been 6 years since I touched my car so my memory is foggy at best...
What does the rear hood latch top part look like? the Part that attached to the rear hood? I order all my parts from cip1.ca (free shipping to Canada) and they don't seem to have it?
I took it off the car in 2010 but forget what it looks like... if I had a pic I could maybe find it?? I can't seem to find any pics of it online...
Anyone know where to get one incase it's gone?
thanks!
here's where it would attach:
motorhead364 Samba Member
Joined: November 04, 2008 Posts: 715 Location: Amarillo Texas
Posted: Sun Feb 19, 2017 8:00 pm Post subject: Re: Rear hood Latch Part... pic??? where to buy? |
Bingo! thanks!... now... if I only knew where mine was... =(
I think it's long gone... didn't see it anywhere at my shop...
Where could I get one? usually Cip1 has everything but no luck finding it there...
thanks! |
c21darrel Samba Member
Posted: Mon Feb 20, 2017 7:38 pm Post subject: Re: Rear hood Latch Part... pic??? where to buy? |
thanks! just messaged the seller |
pabloghia Samba Member
Joined: April 29, 2011 Posts: 144 Location: California
Posted: Tue Feb 21, 2017 5:30 pm Post subject: Re: Rear hood Latch Part... pic??? where to buy? |
Are there any instructions out there that show the proper way in which to install/adjust
this part? _________________ 67 Ghia Cabriolet |
Posted: Tue Feb 21, 2017 7:39 pm Post subject: Re: Rear hood Latch Part... pic??? where to buy? |
I drilled the "escape" hole a few years ago and I have used it many, many times .
It really comes in handy when you over do it on the adjusting.
(In the summer time I have to use the lift offs because of the high temps here. 110+ is not
out of the ordinary).
The way I have been adjusting the deck latch is by leaving everything
finger-tight and gently closing the lid. I then use the "escape hole" and
open the lid. I am assuming everything is lined up now and tighten it up.
This process works pretty good...I just thought maybe somebody out there has a better way.
With lift offs
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Wed Feb 22, 2017 6:37 am Post subject: Re: Rear hood Latch Part... pic??? where to buy? |
The rear decklid latch removal, installation and adjustment is very briefly described on page A61-6 of the 1960 VW Karmann Ghia Shop Manual - Body Section that can be found under the Technical tab at the top of each page here on The Samba. |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Wed Feb 22, 2017 10:59 am Post subject: Re: Rear hood Latch Part... pic??? where to buy? |
c21darrel wrote: |
Many ghias drive around un-hitched. I am right now. Decklid does not pop up and its always easy to open it up. |
This is my solution also. |
Starbucket Samba Member
Posted: Wed Feb 22, 2017 1:30 pm Post subject: Re: Rear hood Latch Part... pic??? where to buy? |
Just wait till the next time you drop the motor then you can close the lid and adjust the pin with ease from inside the engine compartment, meanwhile drive around unpinned. |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2874 Location: Auckland, New Zealand
Posted: Wed Feb 22, 2017 1:33 pm Post subject: Re: Rear hood Latch Part... pic??? where to buy? |
If you don't want to drive around "unhinged", to use Darrel's word, you could simply cut a slot in each of the bolts that hold the female part of the hood-locking mechanism down, like this:
You could then, in the event that your hood release cable should snap or the mechanism malfunction, undo the bolts from underneath with a screwdriver, lift the hood a few inches, get your hand in and release the hood. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
