Notch_Norway Samba Member
Posted: Mon Feb 20, 2017 4:11 am Post subject: 7x17 et40 on stock 64 Notchback. The right tire size? |
Hey, Guys! Just bought a pretty mint condition Notch and im looking for wheels.
Im gonna buy the 7x17 ET40 Raider wheels fully chromed.
But i need some help to get the right tire sizes.
I`ve seen countless of combinations here on the page.
The key is that i dont want to change to longer/shorter axles etc. Just smack them on.
One dude on here said that 195/40-17 all around is the best if you want to go low. And i want to go low Can anyone confirm this? Or maybe post a pick of their ride with 17 inch on and this tire size.
Thanks for all help |
chizucc Samba Member
Joined: August 16, 2012 Posts: 281 Location: Los Angeles
Posted: Tue Feb 21, 2017 2:52 am Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
Yes i have looked at that thread 100 times.
But the one there uses short axles and spacers with the radar rim and 205 front and 215 rear tires. With a type 1 axles and 1/2 inch spacers i have no clue what the difference is from original width.
Is the squareback and notchback the same in terms of fender size?
If so im going to go for 195/40 as that guy in that thread says and hope it wont rub too bad... |
jokke1 Samba Member
Posted: Tue Feb 21, 2017 3:52 am Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
I use 185/35-17 with my Raider 7X17 on my Notch |
Posted: Tue Feb 21, 2017 4:02 am Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
Could you post a pic please? |
tdrrally Samba Member
Joined: January 05, 2011 Posts: 181 Location: charleston,wv.
Posted: Thu Feb 23, 2017 7:34 am Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
I'm working with same sort of thing, I have 4 like new 235/45-17s I have thinking about putting on my 73 squareback on 17x7 wheels with a 40mm offset . I wonder if that is to much tire. That said I'm not beyond some wheel opening work a mild fender flare |
Posted: Thu Feb 23, 2017 7:58 am Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
nothing this crazy
but more like this
Nate M. Samba Member
Joined: August 11, 2003 Posts: 1306 Location: Anacortes, WA U.S.A.
Posted: Thu Feb 23, 2017 9:06 am Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
tdrrally wrote: |
The street tires on the rear of my car are on 40ET wheels and I widened the rear 3" on each side to accommodate them. But I also have Porsche rear suspension which added something like 25mm each side (I can't honestly remember) so it's probably rather apples to oranges.
17x8 40ET w/ 944 rear suspension stock fenders (inner wheel very close to the spring plate):
With 25mm spacers and plenty of room around the spring plate:
After stretching 3" each side VS a stock '71:
Since I used 25mm spacers to set-up the car, I can fit up to a 17x9 40ET 255/40R17 race tires with the spacers and still have plenty of room between the tire and the spring plates.
The bottom line is that there is no one solid answer. Since you're planning a 40ET, that will push the outer lip of the rim outward and cause you problems. If you ran a 17x7 55ET wheel like the early Boxster twist wheels (two pairs of fronts only) on a stock body car, they fit with no modifications at all. Anything with a 40ET and 7" width will cause you to either widen the fenders some or narrow the suspension some. "It's a pimp game" LOL!! _________________ Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!! |
Posted: Thu Feb 23, 2017 9:27 am Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
I like it, have you ever checked your mpg with that set up? |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Thu Feb 23, 2017 10:23 am Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
Nate M. don't get me wrong you t3 inspires me on my build. i mean how much has he wider tires effected the mpg and performance, wide tire is more resistance that is needed in a cornering.
i did not mean to hyjack the thread |
Erik G Samba Member
Posted: Thu Feb 23, 2017 10:28 am Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
I just thought it was funny. I don't think this is his regular driver, it's an auto-x car. You can pretty much throw MPG out the door...
Or maybe you wanted MPG of his Bonneville run? _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Thu Feb 23, 2017 11:10 am Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
I'm working on a daily driver with a 60 round trip so I'm looking for fun and affordable with good looks I want it all lol |
Posted: Thu Feb 23, 2017 11:43 am Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
Im gonna testfit 195/40 late next week. (Since ive already bought the tires)
Will post a pic of my ride then. But im afraid i need 195/40 rear and 185/35 front. Or all around 185/35. We will see! |
Posted: Thu Feb 23, 2017 1:07 pm Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
tdrrally wrote: |
LOL!! Surely you jest sir. . .
Actually, I did with both the 2056cc motor and the 2316cc race motor. When I first got my MS system running and drive-able (plenum based MS2 w/ EDIS), Mario and I did only a good "seat of the pants" tune on the street. Then over the next few months I tweaked the cruise areas of the fuel and ignition MAPs. I typically got about 24-25mpg in city driving and 27-28mpg hwy (typically cruising around 80mph). When I moved to the 235/40R17 from the 205/60R15s, I didn't notice an appreciable MPG drop.
With the 2316cc (it's street-able race motor) in it's current configuration with a dyno tune for max power and nothing else, if I keep my foot out of it (possible but not likely for long ), it gets around 23mpg city and about 24-25mpg hwy. Conversely, on the track at Pacific raceway in 3 20 minute sessions running mostly WOT, I can burn through about 10-12 gallons of premium. It's pretty shocking until you consider I'm running WOT any moment the brakes are not being pressed and the motor operates in the 5.5-6.5K RPM range the entire time. I would estimate somewhere around 6-8mpg on the track, but really who cares.
The key thing though is that I didn't really notice a big change in fuel economy when I moved from my 205s to the 235s. Oil weight and tire pressure play a big part in the fuel mileage equation, probably more than tire width alone. _________________ Regards,
Nate M.
Squarsche build
Posted: Thu Feb 23, 2017 1:14 pm Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
Erik G wrote: |
Or maybe you wanted MPG of his Bonneville run? |
You'd be surprised how much my car is driven throughout the year. I logged about 7K last year with it which is more than most here do in their T3s. I typically only run the big motor Spring to Fall and put in the small motor for Fall/Winter, because it has heat (the wife hates it cold). _________________ Regards,
Nate M.
Squarsche build
Erik G Samba Member
Posted: Thu Feb 23, 2017 2:19 pm Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
Nate M. wrote: |
Erik G wrote: |
You'd be surprised how much my car is driven throughout the year. I logged about 7K last year with it which is more than most here do in their T3s. I typically only run the big motor Spring to Fall and put in the small motor for Fall/Winter, because it has heat (the wife hates it cold). |
that's awesome. that is more that I put on my daily and my fun car combined (I live 2 miles from work... I have to get out and do a 30 mile drive regularly to just not ruin cars from short drive cycles) _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Fri Feb 24, 2017 2:51 am Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
now i want to see a 17x7 et40 on a stock car more |
Posted: Fri Feb 24, 2017 12:41 pm Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
My car arrives on thursday. Will test fit on friday hopefully!
I Will update here. |
Posted: Sun Feb 26, 2017 10:44 am Post subject: Re: 7x17 et40 on stock 64 Notchback. The right tire size? |
i have 15x6s 40et with 195/65-15s on my 73 standard beetle, with the suspension at full travel (on jack stands) the tire rubs the trailing arm in the front, i added a 12mm spacer it still rubs but not as bad. i will check it today at ride height, this may be an issue on a T3 as well |
