Flywheel Samba Member
Posted: Mon Feb 20, 2017 6:30 am Post subject: brake spring |
hello, can someone please tell me purpose of the spring in the pic marked by white arrow. I have some brake shoes with and without this and was wondering what its is and whether it is ok to run brake shoes without that spring
thank you
alanhall Samba Member
Joined: February 18, 2006 Posts: 115 Location: Northern California
Posted: Mon Feb 20, 2017 9:03 am Post subject: Re: brake spring |
I believe this spring holds the shoe against the backing plate to prevent it from moving around and rubbing against the drum. I don't think I would run without them. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Mon Feb 20, 2017 9:58 am Post subject: Re: brake spring |
... am just curious what year that is? _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Mon Feb 20, 2017 10:22 am Post subject: Re: brake spring |
Hi, its a 1943 Type 82 Kubelwagen but I assume all cable brake VWs would be the same.
I just had a closer look at the brake shoes and backing plate as they are currently off the car and it looks like the pin that goes through that spring on the shoe rides on a high point on the backing plate. Infact on close inspection I can see two purpose made dimples in the plates where those pins are supposed to sit. Funny, I never noticed those before.
Thanks very much for the help and pointing me in the right direction
Andy |
brycetx Samba Member
Posted: Mon Feb 20, 2017 7:35 pm Post subject: Re: brake spring |
It seems if it were to keep the shoe from rubbing the drum it would be toward the center of the shoe. It has a pin that goes through and slides against the backing plate and also catches a stop on the backing plate. The spring's position next to the spreader mechanism would suggest it keeps the shoe straight from twisting into the backing plate. The flat spring keeps the shoe from rubbing on the drum. |
Posted: Tue Feb 21, 2017 12:35 pm Post subject: Re: brake spring |
thanks for those details and great pics - nice observations
Andy |
Lars B Samba Member
Posted: Wed Feb 22, 2017 11:16 pm Post subject: Re: brake spring |
I think they prevent the shoe to press against the spreader mechanism causing it to move the other side and maybey move that brake shoe causing rubbing against the drum.
Or
It can also prevent the spreader function to be pressed together so much that it would prevent it to work properly.
Bendix type brakes have an anchor pin it the top preventing the brake shoes to move the pistons over to one side so it wont "drop" out causing leaks.
Think these pins have the same function.
