blakestuff21 Samba Member
Posted: Mon Feb 20, 2017 3:52 pm Post subject: Another Tire Question |
I know there are a million tire threads, but this isn't about what size I should use, it's more general. I'm thinking about having a thicker taller tire in the back, but I don't want the height difference to be too noticeable, so my question is, when is the difference is size look drastic. Half an inch, inch, or two inches. Secondly, does this affect handling much? |
Rev. Scott Samba Member
Joined: June 04, 2006 Posts: 770 Location: Philo, Ca.
Posted: Wed Feb 22, 2017 12:30 am Post subject: Re: Another Tire Question |
Off roaders like wider rears and narrow fronts. Who cares what it looks like. I run an even set of muds all around, and they daily driver handle, as well as have some mud/sand fun. What do intend to do with this set-up most? _________________ "I haven't seen one of those since I was shootin' at 'em!" |
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Posted: Wed Feb 22, 2017 1:03 am Post subject: Re: Another Tire Question |
Bigger tires will bog down the engine a bit and shift your shift points a little earlier to keep the revs up to keep the horsepower up. Of course this is and instant freeway flier as the engine is now spinning slower.
I found a pretty good site that gives the percent of change, width, height and a somewhat useful visual as to what the tire will look like.
https://www.tacomaworld.com/tirecalc?tires=165-80r15-235-60r15 |
Posted: Wed Feb 22, 2017 7:21 pm Post subject: Re: Another Tire Question |
This is strictly on road driving. Currently I'm running tires with a diameter of 25in and width of 8.5in, looks great in the rear but I have some rubbing in the front, and need to size down, so if I drop down to 23-24in, but leave rear as is would it be alright. Really I just don't want it to look like my car is head down and backside up. |
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Thu Feb 23, 2017 10:32 am Post subject: Re: Another Tire Question |
I used this formula on a few vehicles:
(from the web)
Here's the formula for determining the diameter of a tire based on the
Standard size designations:
Diameter (in inches) = (2 * tire-width * aspect ratio / 25.4 ) + wheel rim size
The division by 25.4 is to convert mm to inches.
Using 205/60-15 as an example:
Tire width = 205 mm
Aspect Ratio = 60 (sidewall height is 60% of tire width)
or 0.6 * 205 = 123 mm
Wheel rim dia. = 15 inches
So the diameter of a 205/60-15 tire is = (2*205*0.6/25.4) + 15 = 24.69 inches
It works well, I looked at a few suggested tire sizes for my THING as when I got it I was running 205x70 R15's.
It looked ok but every time I'd get out my right foot would catch the door sill and kinda trip me up.
Plus my 85yr old dad couldn't get his leg up and over to get in so I dropped the tire hight a bit.
I went to either a 165 or 185 x 65 I believe (i'm at work cant verify)
but it dropped the THING about 2 to 3 inches at the windshield post
as when first purchased I couldn't look over the roof easy, it was exact eye level, but now I can.(and my foot don't catch anymore)!
But try it with your current size, get your calculation and take a manual measurement, then experiment with a few diff tire sizes with the formula, it may give you an idea of where the THING will be hight wise when you mount em.
Also, I must have been in the ballpark hight wise as it didn't really affect my speedo either, I've checked it with a GPS and it's about dead on somehow.
But Good luck! Let us know what ya go with.
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
