Type 4 Push rod tube seal removal and replacement
orangebug60guy
Twin #1
orangebug60guy is offline
PostPosted: Thu Feb 23, 2017 11:32 am    Post subject: Type 4 Push rod tube seal removal and replacement Reply with quote
There aren't many threads about this and I know that before I did the job I researched on here to figure things out. I tried making a video for those visual learners. Hope it helps. I'm not saying this is the recommended procedure to do this but the Bentley is pretty vague on the topic.
Feel free to add your comments and tips about the job. I found that once you dig into it it's pretty easy.
Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation.
Tumbledown76
Tumbledown76 is offline
PostPosted: Thu Feb 23, 2017 5:01 pm    Post subject: Re: Type 4 Push rod tube seal removal and replacement Reply with quote
Thanks for posting this, I found it extremely helpful.
Cheers!
'Camel' - '79 Riviera, 2.0L FI, Dakota Beige
60vwnewengland
Twin #2
60vwnewengland is offline
PostPosted: Thu Feb 23, 2017 7:04 pm    Post subject: Re: Type 4 Push rod tube seal removal and replacement Reply with quote
Popcorn
77 Westy - Cape Cod Sage
LLAP
kevin77westy
kevin77westy is offline
PostPosted: Fri Feb 24, 2017 1:03 pm    Post subject: Re: Type 4 Push rod tube seal removal and replacement Reply with quote
Nice! Just 1 comment - I've found that tapping them into the case as shown often causes the Orings to get small nicks/cuts around their edges. I now wiggle them into place much like you removed them. The side to side seems to help the seals stay intact as they slide home..
Randy in Maine
Randy in Maine is offline
PostPosted: Fri Feb 24, 2017 1:30 pm    Post subject: Re: Type 4 Push rod tube seal removal and replacement Reply with quote
Just a suggestion...
I have a pair of these that allow me to use the 90º against the engine case to gently leverage out the push rod tubes. Might have been one of those harbor Freight purchases for cheap money.
http://www.autozone.com/wrenches-pliers-and-cutter...14140_0_0/
The use of Locktite 565 (sort of "liquid teflon") works well on the O-rings to allow them to not leak oil and remain flexible.
orangebug60guy
Twin #1
PostPosted: Fri Feb 24, 2017 2:12 pm    Post subject: Re: Type 4 Push rod tube seal removal and replacement Reply with quote
Thanks guys this exactly what this thread is for. Tips and links to do the procedure right. We'll see how this hold up. Keep the feedback and suggestions coming!
udidwht
udidwht is offline
PostPosted: Tue Mar 21, 2017 12:44 pm    Post subject: Re: Type 4 Push rod tube seal removal and replacement Reply with quote
Your T-stat (bellows) has failed. It's in the open position (engine cold). It should be contracted.
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
