PopPop Jambon Samba Member
Joined: November 23, 2016 Posts: 125 Location: Florida
Posted: Mon Feb 27, 2017 6:44 am Post subject: Need assistance with front brake hose length |
So I am replacing my brake components on all four wheels on my 1968 Bug. I ordered 2 Front brake hoses from JBugs part #113611701D.
First- The invoice indicates...."VW Brake Hose, Front, Each, German, Bug 1967-77" but if you look at the label on the packaging it indicates "Made in Italy"
Also if you go to JBugs website and type in the part #113611701D it comes up as "Front Brake Hose For 1967 - 1977 VW Beetles 380mm Long Sold individually German-Made"
Second- The hose that I received is about 5 inches shorter than the current brake hose and is stretched TIGHT when the wheels are turned to full lock. And the front beam is stock width.
What am I missing? Did I receive an incorrect part? Is there a longer front brake hose for this application? Can someone please tell me the length of their STOCK front brake hose on a STOCK front end?
Thanks
_________________ Eric
VWLM
1968 Beetle 1600 DP
Sort of a Baja
(PO removed the deck lid, cut out the rear skirt and added rear fiberglass fenders, that's about it) |
gt1953 Samba Member
Posted: Mon Feb 27, 2017 6:50 am Post subject: Re: Need assistance with front brake hose length |
Hmm I would not be happy with those results. Call them email them and demand answers. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Mon Feb 27, 2017 7:22 am Post subject: Re: Need assistance with front brake hose length |
gt1953 wrote: |
Hmm I would not be happy with those results. |
I am not happy at all! But I would really like to know what front brake hose I need to get. It looks like the JBugs part #211611701 is a couple of inches longer and should fit even though it is made for 1965-66 VW Bug. _________________ Eric
VWLM
1968 Beetle 1600 DP
Sort of a Baja
runamoc Samba Member
Joined: June 19, 2006 Posts: 5600 Location: 37.5N 77.1W
Posted: Mon Feb 27, 2017 7:30 am Post subject: Re: Need assistance with front brake hose length |
the number 113611701d on the one they sent you should be 390mm (about 15") _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Posted: Mon Feb 27, 2017 7:37 am Post subject: Re: Need assistance with front brake hose length |
runamoc wrote: |
the number 113611701d on the one they sent you should be 390mm (about 15") |
Yes that is correct, 380 mm. I do not know the history of this car but the 380mm/15" hoses are too short. Going to return them and get the 440mm hoses for the 1965-66 VW Bug. That should give me about 2 1/4 more inches to work with.
Still I am being sold German parts and receiving parts that specifically state made in Italy. _________________ Eric
VWLM
1968 Beetle 1600 DP
Sort of a Baja
Chochobeef Samba Member
Joined: May 01, 2013 Posts: 811 Location: Ft. Worth, Texas
Posted: Mon Feb 27, 2017 8:13 am Post subject: Re: Need assistance with front brake hose length |
Febi/Bilstein is german. The manufacturer was in Italy. Still, very poor and misleading advertising. I don't order from jbugs because of this fact.
You might be able to find good brake hose at a FLAPS. Won't be german, but it should work as long as dot approved and the length you are looking for. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Mon Feb 27, 2017 8:41 am Post subject: Re: Need assistance with front brake hose length |
Two months ago I installed Wagner #BH93120 flex hose on the front of my 1970 VW, they fit fine and are NOT tight !!! I got them from Rock Auto. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Feb 27, 2017 9:28 am Post subject: Re: Need assistance with front brake hose length |
Chochobeef wrote: |
Febi/Bilstein is german. The manufacturer was in Italy. |
So it's a German company but production of the part is in Italy. Go figure.
Cusser wrote: |
Two months ago I installed Wagner #BH93120 flex hose on the front of my 1970 VW, they fit fine and are NOT tight !!! I got them from Rock Auto. |
Thanks Cusser, unfortunately the description does not tell me the length of these. If they are the same length as stock, 380mm/15", then my bug won't be happy with them. _________________ Eric
VWLM
1968 Beetle 1600 DP
Sort of a Baja
