Is mine different?
Forum Index -> Accessories/Memorabilia Share: Facebook Twitter
Dan Van 73
Dan Van 73 is offline
PostPosted: Fri Apr 23, 2004 5:50 pm    Post subject: Is mine different? Reply with quote
I own a 1973 microbus. when you open the drivers door the dome light does not come on. but yet if i have the key in and open the drivers door it does come on. it seems that you would want the dome light on at night so you sould see where to put your key! is this normal for an old vw? thak you for your help
53 0val
Samba Professor
53 0val is offline
PostPosted: Fri Apr 23, 2004 9:28 pm    Post subject: Reply with quote
First of all. Does the Buzzer still work when you have the Key in the ignition and open the door? If it doesn't-----that circuit is shorting out your dome light. The dome light should be on in both your cases. My guess is the buzzer circuit is causing your problem. I don't have a 73 to check but all VWs of that era work the same way. Confused
justbuggin
Resident Brit
justbuggin is offline
PostPosted: Sat Apr 24, 2004 2:55 am    Post subject: Reply with quote
Not sure of the wiring on a bus, but it sounds like you've got the live feed coming off the switched positive side of the ignition, shouldn't it come from a permanent live instead??
Rob
www.justbuggin.co.uk
1958 Rag Cal Import
T25 Panel Van
Reply to topic    Forum Index -> Accessories/Memorabilia All times are Mountain Standard Time/Pacific Daylight Savings Time
