vwkafer Samba Member
Posted: Thu Jun 24, 2004 12:40 pm Post subject: Long travel and other sorts |
I Know jack about Super beetles. I have A 71 super beetle and I would like any info about long travel suspensions. or at least how to lift it.
I have built sand rails and a 1968 standard baja bug. I love vw inspired cars and they off road better than my truck. any help would be appreciated |
67bajabug Samba Member
Posted: Fri Jun 25, 2004 4:53 pm Post subject: |
| you could cut and crank the front. |
vicsvw Samba Member
Posted: Sat Jun 26, 2004 7:32 am Post subject: Lift ? |
Not much you can do with the SB
There are special spindels that will lift it a little. Vic.
Parts Book w/Break-Down Schematics and VW part numbers **Index at -> http://www.1800vw.bizhosting.com/page_index.htm |
HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 7034 Location: SoCal
Posted: Sat Jun 26, 2004 3:05 pm Post subject: |
as far as i know, there are no raised spindles for the SB. youre pretty much limited to stock height or lower _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
Posted: Sat Jun 26, 2004 3:06 pm Post subject: |
| 67bajabug wrote: | | you could cut and crank the front. |
definitely cant do this. SB uses coil springs and struts instead of torsion leaves in a beam front end _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
bljones Resident Wit
Joined: February 08, 2002 Posts: 2400 Location: ontario canada
Posted: Sat Jun 26, 2004 7:05 pm Post subject: |
if you have the time and skill, you can fab spacer blocks to mount between the struts and upper mounts which will provide a little lift to the front end, but you are pretty limited by the narrow travel of the control arms. _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
Butters Samba Member
Joined: May 19, 2003 Posts: 289 Location: West Michigan
Posted: Sun Jun 27, 2004 12:26 am Post subject: |
| I wouldn't try off-roading with a SB. A couple of good bumps and the whole front end will be junk. |
Posted: Sun Jun 27, 2004 1:15 am Post subject: |
actually, i've seen photos of this guy who took an early SB off roading and wound up a few feet in the air. on multiple occasions. the car wound up lasting less than a month _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Posted: Mon Jun 28, 2004 10:59 am Post subject: |
My friend has a 71 standard beetle. I took his standatd beetles pan and put my super body on it. (It's already got a baja kit on it.) I also put a 3 inch body lift on it. Now I don't have to worry about the super suspension. Oh they do make lifted spindles but whats the point you will still loose the suspension. |
Posted: Mon Jun 28, 2004 11:07 am Post subject: |
| bljones wrote: | | if you have the time and skill, you can fab spacer blocks to mount between the struts and upper mounts which will provide a little lift to the front end, but you are pretty limited by the narrow travel of the control arms. |
If I wated to I'm pretty sure I could fab a new front suspension. I've noticed that if I can fab a spacer block from the pan head to the controll arms and that spacer block between the strut and upper mount I can get really high but again no matter how high I get it i will still be limited by the travel of the struts. + the struts will break if you apply to much pressure to them. not to mension the tie rods. I would have to extend them to be able to controll the car. Neat idea but doing this would be mostly for show. |
HomespunKustom Samba Member
Joined: January 07, 2004 Posts: 743 Location: SALUTE!!
Posted: Fri Jul 02, 2004 12:07 pm Post subject: |
lifting a sb, although possible, would be good for looks only. strut spacer increase height but not travel. Hack off the front end and either swap in a bj or lp front end or go full custom with coil-overs (probably easier depending on skill and material at hand). the IRS in the rear can be set up in some pretty trick ways. _________________ Before your criticize someone, you should walk a mile in their shoes. That way when you criticize them you're a mile away and you have their shoes!
'68 type 1 Kit
I am Spiderman. (part deux) |
