pickdr Samba Member
Joined: March 31, 2004 Posts: 220 Location: Fullerton, CA
Posted: Wed Jul 07, 2004 10:04 am Post subject: 2 Tone Help |
I'm getting my bug ready for paint soon, and I'm going with 2 tone. my problem is:
i want it to look professional. i know earl sheibe doesn't paint the top hinge completely (dead giveaway that it's done cheap) but the pros paint the whole hinge. but how do the pros paint the door jam? does the white go all the way to the inside, or only about a quarter inch.
if anybody has a picture of the 2tone doorjam where the latch is, that'd be great.
also, what's the best way to paint the hinge so that it doesn't get painted shut, or so that when i start moving the hinge, it doesn't crack and piss me off?
thanks
-dave _________________ Two wrongs don't make a right.
...but three lefts do. |
Blaubus Samba Member
Posted: Thu Jul 08, 2004 8:10 am Post subject: |
before spraying the second color, start by applying the fine line tape with the door in its final adjustment position, then remove the door and mask off the whole opening leaving the jams showing. actually this must be done for both colors. dont worry about the paint cracking on the hinge, just dont apply so much that it runs, and you will be ok with this. |
pickdr Samba Member
Posted: Thu Jul 08, 2004 11:40 am Post subject: |
so both colors continue the 2 tone pattern all the way to the inside? or does it stop just at the edge? _________________ Two wrongs don't make a right.
pickdr Samba Member
Posted: Fri Jul 09, 2004 10:26 am Post subject: |
is there nobody that can help? _________________ Two wrongs don't make a right.
pickdr Samba Member
Posted: Sun Aug 01, 2004 9:20 pm Post subject: |
I'm restoring this post. how far does the paint go? _________________ Two wrongs don't make a right.
Chillkoot Samba Member
Joined: May 09, 2002 Posts: 556 Location: Big Lake AK
Posted: Sun Aug 01, 2004 9:32 pm Post subject: |
how ever far you want it to.. it dont matter...either go all the way.. or.. go into the jams a 1/4 inch it is up to you _________________ While we all hate POH ... Don't be Apathitic to CURRENT owner hacks.
Fiberglass is for boats... Rustoleum is for your lawn mower! |
pickdr Samba Member
Posted: Mon Aug 02, 2004 2:32 pm Post subject: |
FINALLY - Thank you! _________________ Two wrongs don't make a right.
Slowlow Samba Member
Joined: March 17, 2004 Posts: 4121 Location: Northeast Tennessee
Posted: Sat Aug 14, 2004 6:24 pm Post subject: |
We (at my body shop) are in the process of two toning a 71. We plan on only going into the door jam until the small "hump" in the jam itself. But I agree with Chillkoot, as long as the jam paint is a straight line and you cant see the other color in the door seam, it will look fine! _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
willz0072002 Samba Member
Posted: Mon Nov 22, 2004 10:39 am Post subject: im painting mine after.. |
i shot the outside...(i have a square with no hinges exposed) i didnt tape off the inner door jam when i shot it....when im ready to paint the interior i mask the jam, and im taking the 2 tone all the way inside.....i use an airbrush for the dash and doors, so makes masking much easier this way rather than removing the doors to paint the inside of them, etc.......
id open the door slowly when it is still tacking up, to avoid any chipping after it cures...just me... good luck |
