Wolfsburg Classics Samba Member
Posted: Mon Jul 26, 2004 6:49 pm Post subject: Barndoor Tailights and Frese Reflectors. |
Does any body have any hot tips on how to replace the bubble lenses in the Barndoor tailights as I want to get mine rechromed and put my NOS lenses in but are unsure on how to dismantle them the best way.
Secondly,I have a set of Freese reflectors and the glass is broken,has anyone ever replaced the glass in these as I would like to restore these as well as I can not seem to find any Freese reflectors anywhere....any ideas Barndoor guru's ??? |
mkennedy Samba Member
Posted: Mon Aug 02, 2004 9:15 pm Post subject: |
| on the back of the bezel, it wraps around the lamp holder. you will need to bend that lip up(like a pie tin) enough to get the holder out of the bezel. you need to be very careful, use a small flat head screwdriver. when you reassemble just bend the lip back down, your seal will cover any distortion when you mount the lights back on the bus. i hope this helps....mike |
Barndoor Mafia Il Capo
Joined: August 23, 2001 Posts: 5353 Location: EUSKAL HERRIA
Posted: Mon Aug 02, 2004 9:50 pm Post subject: |
If I were you..................I'd go to a jeweler. These guys have those special tools that are super strong and unbreakalbe, and have the angles and curves to bend the lense out then back in. Same goes for the taillights. It's hard work but I have seen it done. Your better off holding out until the FRESE ones come along? But it's your call.
or you can ask Linda his opinion. He knows everything!
Laydo _________________ http://barndoormafia.skynetblogs.be/ |
EverettB  Administrator
Joined: April 11, 2000 Posts: 42204 Location: Phoenix, AZ
Posted: Tue Aug 03, 2004 10:03 am Post subject: |
I've taken reflectors apart and replaced the glass. I went really slow with a small flat head screwdriver. To reassemble, I rolled the edge along a piece of wood.
They came out pretty good. You could tell they had been opened up if you really looked close but once they were mounted 99% of it was hidden. _________________ How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
"Water is the only drink for a wise man" | "Communication prevents complaints" |
