barrettw Samba Member
Joined: August 03, 2004 Posts: 32 Location: Tacoma, WA
Posted: Thu Aug 05, 2004 10:33 pm Post subject: Unique tools needed for Vanagon repair? |
| Buying my first vanagon and plan to do most repairs and upgrades myself. Anyone have suggestions about any unique (VW specific) tools needed for work on Vanagons. |
TeamSpatula  Samba In The Rain
Joined: February 03, 2004 Posts: 5185 Location: Hickory, NC
Posted: Fri Aug 06, 2004 5:16 am Post subject: |
Not many VW-specific tools, unless you go really deep into transmissions, & other specialized systems. A *good* set of metric scokets & wrenches will take you far. Also, a good digital multi-meter will prove invaluable with electrical & Fuel Injection.
Dive in!
 _________________ <---Air Cooled Search & Rescue Team - STICKERS & Tshirts for sale!
Seeking a camper!!!
1972 Jeep Commando FOR SALE/TRADE
1981 Ford F100 rescue truck
http://www.TeamSpatula.com |
Randy in Maine Samba Member
Joined: August 03, 2003 Posts: 29759 Location: The Beach
Posted: Fri Aug 06, 2004 7:08 am Post subject: |
I would add a Bentley manual to the collection.
Dwell/tach and a timing light are also useful.
I also like a nice asortment of screwdrivers and a set of "triple square sockets" for the CV joints. A pair of circlip pliers is also useful.
I use my 2 torque wrenches (3/8 in inch pounds and 1/2 in foot pounds) enough to make them both worth having. |
Posted: Fri Aug 06, 2004 12:00 pm Post subject: |
| Thanks to all for the great advice. As a testament to the Bentley Manual, I actually ordered it before I found a vanagon to buy. Has always been critical on my A1 & A2 cars. |
johnboy Samba Member
Joined: May 20, 2004 Posts: 16 Location: College Station Texas
Posted: Fri Aug 06, 2004 7:49 pm Post subject: |
In addittion to a good set of metric sockets and wrenches,and a full compliment of screwdrivers, pliers, hammers, etc, there are a couple of specialty tools that owning a Vanagon increases the probability of needing;
1 A 46mm axle nut socket (very affordable from Bus Boys or Bus Depot)
2 A 6mm allen headed (or 12 spline, look before you buy) socket for the CV's
3 Clutch alignment tool for manual tranny (again, cheap from BB or BD)
4 The large transaxle drain plug socket (for manual trannies only, I suspect)
5 As many manuals as possible. I like to cross reference procedures. _________________ 1980 Aircooled Westy
If not me then who, if not now then when? |
Posted: Tue Aug 17, 2004 8:43 pm Post subject: |
Wanted to add to my orginal question so others may benefit.
Just replaced the shocks on my '88 Wolfsburg and came across a unique tool needed for installing Bilsteins.
In order to tighten the top lock nut to the body on the front shocks you will need a 5mm hex to prevent the shaft from turning. Problem arises when you get the nut fully tightened down and then realize your hex wrench is now pressed against the wheel well and can't be removed from the shock shaft.
Take any cheap 5mm hex and saw or grind down most of it until you have about 10mm of hex left. This should allow enough room to remove from the shaft after you have fully tightened the nut down. |
