Bklyn63 Samba Mafioso
Joined: August 24, 2002 Posts: 966 Location: "What am I, a mirage?"
Posted: Fri Aug 13, 2004 5:26 pm Post subject: Rust removal pic opinions needed |
what do you guys think I should do about these few holes i have in the ragtop section? I have a few holes I grinded and wirebrushed the rust off. some are in awkward areas. can I just weld the small holes closed and grind down to repair them or should I cut them out?
thanks
Leo |
Monsterbeetle Samba Member
Posted: Sat Aug 14, 2004 4:20 pm Post subject: |
There are only a few ways to properly eliminate rust. Cut it out like you suggested or sand/bead blast. From the pic, it looks like you might have trouble welding the areas shut, as the rust weakened surrounding metal is likely to blow out as you weld. A small handheld bead blaster (with a sheilding cup or boot to minimize the mess) will clean the area of all rust. The weak spots will most likely blow open with this method leaving the area "swiss cheesed". If its not too holely you can tack the holes shut. If it is, its cut out and patch time.
This being said (as the "correct" way to repair rust) you could always paint the area with POR 15 etc. Then smooth the holes with a USC product known as All-Metal. All-Metal is a metal reinforced body filler that is a good bit stouter then plain old mud. Hope this helps. |
Posted: Tue Aug 17, 2004 4:59 am Post subject: |
well, I tried to fill the holes, only filled a few of them. I then tried to cut out a section. one little area was easy to do but another was almost impossible to reach to cut ou. I grinded it out and I'm going to use all metal in it. I'll them epoxy prime then paint. |
