Stanw3 Samba Member
Joined: September 26, 2003 Posts: 1077 Location: Albuquerque, NM
Posted: Mon Aug 16, 2004 11:26 pm Post subject: How to fix floor pitting |
My 66 double door has minor rust up front. In these pics you can see it - not too bad really but there are some pinholes that show up best in the second picture. What should I do to fix this? Does this warrant a repair panel????
_________________ Sanborn7
www.facebook.com/Sanborn7 |
E-boyz67 Samba Member
Posted: Tue Aug 17, 2004 1:00 am Post subject: |
I would replace that panel. _________________ 2-67
1-67vert |
Bklyn63 Samba Mafioso
Joined: August 24, 2002 Posts: 966 Location: "What am I, a mirage?"
Posted: Tue Aug 17, 2004 4:56 am Post subject: |
use some filler called metal to metal by evercoat. |
Black58EuroBug Samba Member
Joined: April 04, 2004 Posts: 180 Location: 8,500 feet high in Nederland, Colorado
Posted: Tue Aug 17, 2004 10:56 am Post subject: |
POR-15 in silver contains aluminum and they claim that if you back the pin holes with some tape and paint over the rusted area with the POR-15 silver it will fill up and seal up the pin holes. Then you can paint over it or fill and smooth.
I used the POR-15 black on my Beetle pan (I had no pin holes) and the stuff is indestructible, and went on very easily, quite impressive stuff. _________________ Kimberly
9/9/57 European Beetle L41 "Schnitzel" |
Posted: Tue Aug 17, 2004 11:05 am Post subject: |
that stuff is the best for undercoating and rust treating.Just dont get it on your fingers.. |
Stanw3 Samba Member
Posted: Tue Aug 17, 2004 10:18 pm Post subject: |
thanks guys - time to go shopping. I'd rather not cut the floor - I'll try the metal filler and see how it goes. Where do I have to go to get Por 15? Will my paint store have it? _________________ Sanborn7
Big Jim Samba Member
Posted: Tue Aug 17, 2004 11:16 pm Post subject: |
Auto paint store should have it. Also, maybe a full-line hardware store. They do have a web site and you can order on-line, if you need to. |
ROADKILL Samba Member
Joined: July 22, 2004 Posts: 347 Location: Gilbert, Arizona
Posted: Wed Aug 18, 2004 12:24 pm Post subject: |
the silver por should do that easy without hacking up your bus. |
Posted: Thu Aug 19, 2004 7:30 am Post subject: |
Just order the POR-15 from their website (www.por15.com). I always do and never a problem, sometimes they have special deals also. The are located in New Jersey and ship from there. _________________ Kimberly
inksling Samba Member
Posted: Thu Sep 30, 2004 1:00 pm Post subject: |
ok, what i do is this. grind away the rust, coat it in fiber glass resin, allow to tack, then reinforce with fiber glass, then let is set up, then coat the whole floor board in rhino coat. but thats just me. _________________ Show me a man with a tattoo and I'll show you a man with an interesting past. ~Jack London
www.inksling.com |
Notty's Owner Samba Member
Posted: Sat Oct 02, 2004 12:21 am Post subject: |
Once this filler/paint is used, how does the integrity of the pan/piece hold up compared to a replaced piece? _________________ '65 bug
'67 sunroof bug
'58 Euro bug
'64 Kombi Bus
'65 sunroof Notch
'12 CC
'10 Jetta Wolfy |
lenwood Samba Member
Joined: November 10, 2002 Posts: 375 Location: all the bling bling in san fran,and then some
Posted: Sat Oct 02, 2004 8:32 pm Post subject: pitting floor |
stan i had the same problem. i wire brushed the floor,used jb weld to fill the small pits...(works great but let it dry,sanded it smooth, then i applied a coating called rust bullet. dude, this stuff is the shit! works great,floors are solid. did the whole front floor in my s/c and plan on coating the whole t chest area and gas tank area. check it out at www.rustbullet.com cheaper and easier to apply than por-15 |
