neill in the uk Samba Member
Posted: Sun Aug 22, 2004 2:42 pm Post subject: need a little help with paint |
first off i have painted the lower half of my car with one part primer sanded it with wet/dry 800 to a good finish. and have painted the top coat on and it has covered real well a nice even colour the only problem is its a rough finnish on the paint to give you a idea how rough i would say it has the texture of 1200 grit wet/dry (you can laugh now if you want)
if i sand it with 1200 wet/dry then use a cutting compound will it come out ok
i may have thined the paint out to much would this have caused the problem
thanks for your help and i have hit the search button |
Chillkoot Samba Member
Joined: May 09, 2002 Posts: 556 Location: Big Lake AK
Posted: Sun Aug 22, 2004 7:34 pm Post subject: |
to much thinner or to much distance between your gun and the panel..(more likely)
should wet sant and buff out.. but I would go to 2000G or higher... _________________ While we all hate POH ... Don't be Apathitic to CURRENT owner hacks.
Fiberglass is for boats... Rustoleum is for your lawn mower! |
Big Jim Samba Member
Posted: Sun Aug 22, 2004 9:36 pm Post subject: |
or possibly too fast a thinner like using a cool temp reducer when it is actually hot. Another thing to look for is that coverage does not alway mean you applied enough paint. You need the lighting so you can see the reflection of the light and make sure you achieved a full, wet coat. It should be dead smooth and shiny. Dry spots will looked covered straight on but will dry with a texture like you describe. If it is a solid color, you can probably color sand it out. If it is a metallic color, you will have to sand flat and reshoot. Sanding metallics cuts in to the metallic flakes and ruins the appearance of the paint as well as leaving them exposed for weathering. |
Posted: Sun Aug 22, 2004 9:42 pm Post subject: |
Big Jim wrote: |
I didnt think about reducers..I been painting in a booth for to long.... _________________ While we all hate POH ... Don't be Apathitic to CURRENT owner hacks.
Posted: Mon Aug 23, 2004 12:41 pm Post subject: |
thanks for your help i think the problem was with the mix to much thinners thankfully its a solid blue
i am going to sand it down 600 wet/dry and start agian
thanks for your time in helping me |
