verde Samba Member
Joined: October 11, 2003 Posts: 35 Location: Washington DC
Posted: Tue Sep 21, 2004 7:38 am Post subject: Good paint supplier Nothern Virginia? |
Hi, I'm in the middle of restoring the paint job on my '79 Westy Bus. The PO had a type of dark green paint somewhat metallic looking, I went to Mattos Pro Finishes Falls Church Virginia and the guy looked at the flakes and said he could match the paint and for a half gallon it would cost me $356. Doesn't that sound excessive? Does anyone know of a cheaper paint supplier that will match my buses current paint in Northern Virginia?
Thanks,
Verde _________________ -----------------------------------------
Verde - '79 Campmobile |
tacky Samba Member
Joined: April 21, 2004 Posts: 577 Location: highways of agony, va.
Posted: Sat Oct 02, 2004 8:39 am Post subject: |
i am in the same region as you. nva. check the mattos in manasas, maybe the guy you talked to did not know what he was talking about. that seems high to me. _________________ "Everyone reading this is a PO." |
verde Samba Member
Posted: Mon Oct 04, 2004 6:14 am Post subject: Sherwin Williams Fairfax |
Thanks for the reply, but I found a paint supplier that was less expensive then Mattos. The Sherwin Williams Automotive Finishes in Merrifield Fairfax carries an inexpensive line of paint called DIMENSION Refinishing System. The staff was very knowledgeable and helpful, they made sure I had all the proper sealer, reducer and hardener in the correct measurements to insure a gorgeous do-it-your-self paint job. If you're in the Northern Virginia area and you need help touching up or painting your vehicle they can help and also provide classes on basic painting techniques.
Cheers,
