74 super Samba Member
Joined: May 27, 2004 Posts: 257 Location: dayton,ohio
Posted: Mon Oct 04, 2004 12:13 pm Post subject: to weld or not to weld? |
i have a 74 super and in front of the battery the is a nice size hole and i dont have a welder so i want to know if i can put in a new piece of sheet metal with pop rivets or sheet matal screws? |
fastorange72 Samba Member
Joined: August 11, 2004 Posts: 254 Location: BucksCo, PA
Posted: Mon Oct 04, 2004 3:51 pm Post subject: |
Pop rivets will work. I have done that before and it worked out fine. Just cut out a larger area so that you are not trying to rivet into surrounding rust. Good luck... |
Bklyn63 Samba Mafioso
Joined: August 24, 2002 Posts: 966 Location: "What am I, a mirage?"
Posted: Mon Oct 04, 2004 5:08 pm Post subject: |
I would pop rivet it in you situation. but I would also buy some seam sealer from you local autobody supply house and coat the both sides under neath and inside. You dont want moisture to get into the seams and rust all over again.
I then would finish it off with por -15 |
Mr. Bungle Samba Member
Joined: December 11, 2003 Posts: 1705 Location: Vancouver BC, Canada
Posted: Mon Oct 04, 2004 5:11 pm Post subject: |
you can, but it's just a bandaid. water will collect between the pan and the sheetmetal patch and the hole will get bigger before you know it.
the proper way would be to buy a repro rear pan 1/4 and cut out the hole and rust surrounding it and weld in the new peice, seal it and go over it with por 15 or just bullet. then you wont have to worry about it ever again. |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Mon Oct 04, 2004 5:20 pm Post subject: |
Bklyn63 wrote: |
If you're going to do POR15, then just use the patch kit from them, which is like fiberglass mesh. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Posted: Mon Oct 04, 2004 6:37 pm Post subject: |
thanks |
JoelH Samba Member
Joined: October 16, 2003 Posts: 1312 Location: North Dakota
