epitch1 Samba Member
Posted: Thu Oct 07, 2004 7:37 pm Post subject: Zero Rust |
anyone know if Zero Rust is as good as por15 or rust bullet. |
Kubel Nick Samba Member
Joined: August 12, 2003 Posts: 1369 Location: Fort Worth, TX
Posted: Thu Oct 07, 2004 8:15 pm Post subject: |
anything's better then POR-15 |
gerg a.k.a. 6volt65
Joined: April 25, 2003 Posts: 5454 Location: Monroe, LA
Posted: Fri Oct 08, 2004 6:39 am Post subject: |
Is that because of the tremendous prep time or is it really that bad? I used it and liked it . . . . _________________ Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
Posted: Fri Oct 08, 2004 3:37 pm Post subject: |
Tremendous prep time, uncertainty if it will unstick weeks or months later, and it's the most expensive protection coating you can buy. Just my 2 cents. Yes it may work great, but there are alot better and cheaper products out there, that's all I'm saying. |
gerg a.k.a. 6volt65
Posted: Fri Oct 08, 2004 4:10 pm Post subject: |
Got ya! I wish i had investigated before I bought it . . but yes, TREMENDOUS prep time and costly too. I completely agree! _________________ Gerg
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
willz0072002 Samba Member
Posted: Sun Nov 21, 2004 7:01 pm Post subject: well see if it works |
i have used por 15-but just tried zerorust on some lighter areas...well see if it comes through my candy paintjob.....livin dangerously\ |
abdon Samba Member
Posted: Thu Dec 02, 2004 8:58 am Post subject: |
Kubel Nick wrote: |
It boils down to one thing; Do you want to take it to the metal or not? For floors I will always strip it to the bone, which means that preparation for POR or anything else is the same.
The only time you would be uncertain it would not stick is if you didn't apply it correctly. |
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Thu Dec 02, 2004 9:38 am Post subject: |
i just recieved my first quart of masterseries ct and the instructions seem very similar to por-15...Masterseries say that you CAN apply it to a roughened rusty surface, but then they go on and suggest that you clean it as best you can, degrease it, etch bare metal etc....
so i take it that, no you don't NEED to follow all the prep suggested by POR-15 but you'd be better of...and same goes for the other competitor products...comes down to the fact that there really is no easy way...esspecially if you want to be assured of a good bond
for those dealing with winter, MasterseriesCT say you can use on metal surfaces at air and surface temps above 32*F....POR-15 doesn't give an exact temp range in their instructions....i am happier with the price and instructions supplied with masterseriesct... _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
Levonbenelli Samba Member
Posted: Thu Dec 02, 2004 5:40 pm Post subject: |
I bought a gallon of zero rust for $50 and the guys at the paint store told me it was a great product (after I decided to buy it) at first they were trying to push the por-15 on me...better profit margin. I've coated my pans and so far I'm satisfied....seems pretty solid (54 percent by volume to be exact)
Oh...and I have the pamphlet that came with it if you have any specific questions. _________________ Wanted: flipseat parts: rear jump seat, folding chair, cups |
desrat Samba Member
Posted: Tue Dec 07, 2004 5:36 pm Post subject: |
SEM makes a product called Rust Shield that can be purchased at your automotive paint stores. Works well. Comes in various colors and can be rolled, brushed or sprayed. It actually prevents rust from growing. |
Stevie Fierce Samba Landscaper
Posted: Tue Dec 07, 2004 6:58 pm Post subject: |
www.masterseriesct.com
chuck also sells it on thesamba. i just ordered my first quart of primer and chassis black, as well as ag-111 (yellow) for my snow plow. i LOVED the results. i once painted a trailer with POR-15 and it was GARBAGE! |
bam Samba Member
Joined: April 28, 2004 Posts: 691 Location: Cameron park CA
Posted: Tue Dec 07, 2004 7:07 pm Post subject: |
naval jelly then etch primer all the way......anything that bonds directly to metal will prevent rust as long as the rust is removed first.....
epoxies arte good
ive used por 15 and wasnt that impressed _________________ hi |
