Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sun Nov 16, 2014 5:33 pm Post subject: |
Straightened paper clips are good for opening CD drives.
Straightened/cut coat hangers are great for cleaning lint of Mrs. Cusser's two vacuum cleaners.
O-rings are good to replace CD-drive drive belts so the %^&%##^%*&%^# will open/close. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Sun Nov 16, 2014 7:49 pm Post subject: |
mark tucker wrote: |
bandaids are always nice.....says the man bleading from many fingers and arms and leggs.......kinda of a clutz this week. |
Who needs a band-aid? A piece of paper towel held on by electrical tape works just fine. _________________
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
VW_Buggsy Samba Member
Posted: Tue Nov 18, 2014 7:35 pm Post subject: |
Scrap wood. Lots of cut off pieces anywhere from 6" to four feet or so of boards and square posts (4x4, 6x6, etc.) and various thicknesses and shapes of plywood scraps. All leftover from various projects so little to no real cost but I use various pieces just about every time I work on my rides.
They are wheel chocks, pry bars, a little extra height on the Jack or under the Jack stands, protective pieces, soft hammers, spacers, something to drill metal over, buck boards for metal shaping, soft jaws for the vise, and whatever else comes to mind. |
KTPhil Samba Member
Posted: Tue Nov 18, 2014 10:37 pm Post subject: |
6x9 oval piece of plywood, cut out of a panel used for a speaker panel behind the backseat of my '67 Bug back in high school. Installed classic Jensen TriAxial speakers. Still have the cutouts. Now use one as a support plate on my floor jack when lifting the engine. Since I bought the panel for the car, the "holes" are free! |
daven Samba Member
Joined: January 13, 2009 Posts: 351 Location: Dayton OH
Posted: Mon Nov 24, 2014 6:41 am Post subject: 3/8 inch copper water line |
For a handy dandy cheap tool:
I use a section (3-6 inch) of 3/8 soft copper water line to make a tool to use when wire wheeling rust off bolts and studs.
The 3/8 inch line is just big enough to allow a 6mm threaded bolt/stud in. Use a hammer to gently crush the pipe to impress the threads onto the copper line so that you can "screw" the bolt into the pipe. Use the pipe as a handle when wire-wheeling the bolt (keeps from skinning your fingers or having the thing launch across the room).
Same hold true for a 1/4 or 1/2 inch soft copper line for smaller/bigger diameter bolts/studs.
Dave |
bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Mon Dec 01, 2014 11:45 am Post subject: |
Electrical tape - when the part of the watch band that holds the extra band in place broke, I took it to a watch repair place and they said the part isn't available. He said to use electrical tape. So rather than throw out the watch, I took his advice. This is my watch that I use for running, playing, etc. Guess I'll keep using it till the watch quits. Sounds cheap, I know. But no one notices, myself included.
Cusser Samba Member
KTPhil Samba Member
Posted: Mon Dec 01, 2014 12:28 pm Post subject: |
Real Men use duct tape.
Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1321 Location: Bella Coma Canada
Posted: Tue Dec 02, 2014 11:48 am Post subject: |
or a Velcro strap _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy DD
and NUTS |
c21darrel Samba Member
