vwpussycat Samba Member
Joined: September 28, 2004 Posts: 2 Location: las vegas
Posted: Tue Oct 12, 2004 2:51 pm Post subject: need to match new wheel to other 3 |
one of my wheels is bent. If i cant straighten it i'll have to match the new one to the color of the others.
What are my options, how do i know what kind of paint to buy? Can i paint it myself?
Girls ask the dumbest questions but oh well fuck it you guys are VW Gods so I am in good hands right? |
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Tue Oct 12, 2004 3:08 pm Post subject: |
what year and model vw?...some vw types have standard colors for various model/years and you might get an exact color. also check wolfsburg west's online vw color charts
it is not hard to paint wheels, do you have spray equipment or are you thinking rattlecan job?
just mask off the tire and make sure the surface you are painting to is clean of flaky paint, rust, brake residue, and grease (which it should be if it is a new wheel).
not sure if new wheels come primered in a quality primer or not. if it is bare steel, your process should probebly include etching the metal with a metal etch product, then apply a primer, then paint.
one precaution you should take is to file or sand off the paint where the lugbolts hold the wheel onto the hub. This is because the torque that is required to attach your tire to the hub can crack the paint and allow the wheel to loosen on the hub. worst case scenario is the occasional wheel falling off. so be safe and remove that little bit of paint...
good luck... _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
Posted: Tue Oct 12, 2004 6:13 pm Post subject: painting a new wheel |
worse case scenario isnt too bad VW's still drive on 3 wheels.
Thanks BIG. do you think i could just straighten the wheel without messing the paint up?
how?
I love my 64 resto with babyblue rims
I will try to post a pic of my :scatter: rub-a-dub |
Foxx Uncle Meat
Joined: August 27, 2001 Posts: 4897 Location: at the computer,.......DUH!
Posted: Mon Oct 18, 2004 5:33 pm Post subject: |
depending on how bad the rim is bent,it prolly won't be able to be strighten the wheel back to true.
if you have to get a replacement rim, think about painting all 4 of your rims so they will match. or,... just get one rim and run it and pray you can find a match at a swap meet or,...
take a picture and post an ad in the wheel section and maybe someone will be able to come up with a match. _________________ Frank
OG JHC
59 panel
Sarcasm is the body's natural defense against stupidity. i seem to use a lot. |
