Stanw3 Samba Member
Joined: September 26, 2003 Posts: 1077 Location: Albuquerque, NM
Posted: Wed Oct 13, 2004 1:41 pm Post subject: Repairing "Oilcans" |
I'm working the nose on my 66 bus. It had been pushed in pretty good - I've beat back out fairly straight and am ready to start skimming it with el Bondo - BUT - I have an "oilcan"effect on both sides of the middle seam - where the largest area of sheet metal is. On my 61 that has never been hit or worked there is some of the same thing so maybe it can't be eliminated??? My concern is if I lay a thin layer of bondo over it will it crack and break out the first time someone leans against the nose?
How can I eliminate the oilcan effect all together?
Thanks! _________________ Sanborn7
www.facebook.com/Sanborn7 |
lonslo Samba Member
Joined: December 17, 2003 Posts: 1110 Location: Osideornoside
Posted: Wed Oct 13, 2004 3:09 pm Post subject: |
The bondo will crack in time. You need to heat shrink the surounding area till it cherry red with a torch and cool it off with direct contact with a wet towel. |
Stanw3 Samba Member
Posted: Wed Oct 13, 2004 3:12 pm Post subject: |
do I heat the center of the oilcan area or the perimeter of it?
Thanks _________________ Sanborn7
diy570 Samba Member
Joined: September 19, 2003 Posts: 1062 Location: Maggie Valley, NC
Posted: Wed Oct 13, 2004 5:17 pm Post subject: |
start at the highest, most raised spot first. only heat small amounts at a time. do not heat it up past cherry red or you could start melting. a good rule of thumb is to heat an area the size of the face of a body hammer. once you heat it up, tap around the area lightly with your hammer to concentrate the metal. then you cool it with your rag. move on to the next highest spot. patience is key! |
lonslo Samba Member
Posted: Wed Oct 13, 2004 10:43 pm Post subject: |
sorry i forgot to tell you about tapping it w/a hammer. |
John Kelly Samba Member
Joined: March 17, 2002 Posts: 477 Location: Moclips WA
diy570 Samba Member
Posted: Thu Oct 14, 2004 2:04 pm Post subject: |
ive been meaning to check out a shrinking disc. ive heard about them, but never seen them in action. |
Stanw3 Samba Member
Stanw3 Samba Member
zimblewinder Samba Member
Joined: January 22, 2004 Posts: 893 Location: Australia
Posted: Fri Oct 15, 2004 7:26 am Post subject: |
Hey Stan , thought Id throw in my 5c worth since I just did my nose over too. It had some really hard folds because it had been damaged, kicked out, and damaged again Id say. Anyway... the shrinking disc it the ants pants!!!! I have never done panel work with just a heavy ball piened hammer before but thats all I used with the shrinking disc and a bucket and sponge and its now original shape and baby butt smoothe. I thought youd like an opinion on one of these from someone other than the maker. Believe me its as good as he says!!! (PS thanks John , very happy with it) _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism |
