epitch1 Samba Member
Posted: Sat Oct 23, 2004 11:58 am Post subject: painting new floorpans |
Just bought new floor pans for my 75 beetle.Is the primer on these a quality primer thats good enough to just paint right over with enamel,or should i strip them to bare metal and coat with por 15 to eliminate future rusting? |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Sat Oct 23, 2004 6:04 pm Post subject: |
Depends on the manufacturer of the pans...most of the black pans, the primer is el cheapo... use a screw driver and scratch one, if it scrathes real easy then a rag soaked in laquer thinner will probably wipe the stuff right off. Then use I use a good epoxy primer on them and have tried a variety of coatings... I'm really liking the bedliner stuff on my pan jobs these days... |
Posted: Sun Oct 24, 2004 3:46 pm Post subject: |
they are brazilian made and are black.i wiped them with acetone and no paint came off,but they did seem to scratch sort of easy.not sure what to do now. |
Miguel Arroyo Samba Member
Joined: April 02, 2004 Posts: 3122 Location: Miami Beach, Florida
Posted: Sun Oct 24, 2004 3:48 pm Post subject: |
I would not trust them. I would paint and use the bedliner for sound insulation. Make sure you do both sides. Good luck. |
Mr. Bungle Samba Member
Joined: December 11, 2003 Posts: 1705 Location: Vancouver BC, Canada
Posted: Sun Oct 24, 2004 5:03 pm Post subject: |
i agree with the above posts. get rid of that primer.
a big part of getting a good result is preparation. make sure all that cheap crap is off, epoxy prime and paint.
good luck. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Sun Oct 24, 2004 5:06 pm Post subject: |
Paint them with POR15 and be done with it.
I'd strip them first and paint them. That way there's less to do after they've been weld in. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Oct 24, 2004 9:25 pm Post subject: |
Should i do the same to the heater channels when i get them.they are the econo ones w/o heat tubes and i think the bottom plate is already welded on. |
Posted: Sun Oct 24, 2004 10:25 pm Post subject: |
epitch1 wrote: |
absolutely.
you may want to coat the insides of the channels aswell. i will be doing the same soon, and i will either waxoyl the inside or paint in there. |
diamondblue69 Samba Member
Joined: October 23, 2004 Posts: 56 Location: on the NY /ontario border
Posted: Mon Oct 25, 2004 6:43 am Post subject: |
i picked up a new heater channel for my super beetle at a swap meet .
it had been sitting awhile and was full of surface rust (that lowered the price!) . i drilled out the spot welds and removed the bottom plate , derusted the inside and painted it . at the factory they painted only the
exterior leaving the interior unprotected . it was made by veng. |
