OLDveedubs Samba Member
Posted: Tue May 12, 2015 6:51 pm Post subject: |
All finished up.
_________________ -Ryan
Restoration Updates
www.my59bug.com
"Perfection through inspection." |
My57Oval Samba Member
Posted: Tue May 12, 2015 7:39 pm Post subject: |
Just to be clear, RM Uno HD is a BASF brand line of paint and not Glasurit.
I thought it was a glasurit line but it's not, it's BASF. So it's interesting that the code L29 was available in the BASF Uno Single Stage line.
Great work! Your tank and other items look fantastic. Much more interesting than black too.
Rob |
Posted: Tue May 12, 2015 8:02 pm Post subject: |
BASF owns Glasurit _________________ -Ryan
Restoration Updates
www.my59bug.com
Posted: Tue May 12, 2015 8:28 pm Post subject: |
Thanks Ryan! Didn't know that. |
Posted: Tue May 19, 2015 1:42 pm Post subject: |
Buy RM UNO paint for your tank online! Problem solved.
1) Qt of L29
2) Qt of DH 44 Hardener
3) Qt of UR 50 Reducer
Squirt and Done!
http://buyautopaintonline.com/
Rob |
Posted: Tue May 19, 2015 1:48 pm Post subject: |
OLDv, do you think a Quart will be sufficient to paint a tank? Couple of coats?
Rob |
Posted: Tue May 19, 2015 2:02 pm Post subject: |
I painted the tank, wiring cover, trunk mat, 2 glove boxes, the heater muffler covers, arm rest support, and turn signal support all with 1 pint. Some left over. 2 coats on everything but 3 on the tank. _________________ -Ryan
Restoration Updates
www.my59bug.com
Posted: Tue May 19, 2015 2:06 pm Post subject: |
OK, wow. Maybe I'll get a gallon and start a tank restoration sideline...
Rob |
Posted: Fri Jun 05, 2015 10:51 am Post subject: |
I think I lucked out with this. So, there is a powder coating outfit in my area. I wanted to try powder coating a tank I had, to see what the finish would look like, how durable it would be etc.
All I had was a '56 tank that I got here on The Samba a while ago. It's not "correct" for my car, having the 2 horizontal ribs rather than the 4 vertical ribs. So I decided I would have it powder coated.
I chose a color off the RAL Color Chart: http://www.ralcolor.com/
I think I chose this color but would need to call the PC to verify:
RAL 5014 096-111-140 #606E8C Pigeon blue
I wasn't expecting much and since it's kind of my "backup" tank, I really wasn't concerned that it would be color correct. Check it out, not that bad eh? Way too glossy but who cares, it's the gas tank!
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Sun Jun 07, 2015 6:06 pm Post subject: |
It's not close to Dove Blue, that piece of Bus is much more blue.
This is what it looks like in the car, with the coffee cup and extension cord there for reference.
But I'm fine with the color. Although the guy messed up the collar of the fuel fill neck and didn't paint it all the way up to the lip..
When I fix my '57 4 rib tank, I think I am going to go with satin black because I think it looks better than even the proper original grey/blue VW color would look.
Rob |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Fri Jun 26, 2015 8:19 am Post subject: |
I never came back with an installed picture. I had my local paint shop mix up the L 29 code, and while I am ok with the color, it doesn't/didn't match the old tank.
_________________ Plate of shrimp |
stale air Samba Member
Joined: August 23, 2007 Posts: 5148 Location: Senoia Ga, formally NorCal
Posted: Fri Jun 26, 2015 8:46 am Post subject: |
_________________ WANTED: Henry Veale Santa Rosa plate frames
Posted: Fri Jun 26, 2015 10:13 am Post subject: |
Whose tank Stale?
R |
Posted: Fri Jun 26, 2015 10:16 am Post subject: |
rkeyworth wrote: |
Whose tank Stale?
R |
Mine. _________________ WANTED: Henry Veale Santa Rosa plate frames
billb Samba Member
Joined: October 23, 2005 Posts: 369 Location: Austin, Texas
Posted: Mon Dec 11, 2017 2:55 pm Post subject: Re: Color for gas tank - Oval Beetle |
This is an old thread but I wanted to give it a bump for anyone looking for L29 Blue Gray.
When I looked for a quart of Glasurit paint for my tank it was going to be $580 (without shipping) for the paint, catalyst, and reducer.
TCP Global (http://www.tcpglobal.com) had an exact paint match from a part and it was around $85 (plus shipping).
boxkiteflyer Samba Member
Joined: May 22, 2008 Posts: 261 Location: Taylorsville, KY
Posted: Mon Dec 11, 2017 7:06 pm Post subject: Re: Color for gas tank - Oval Beetle |
Thanks for the 'bump'! I need to get my tanks repainted. You can see the bad job of picking the paint color myself if you look at the tanks in my gallery. I'd put a photo here but for the life of me can't figure the process out. I'm kinda stupid when it comes to some things. |
billb Samba Member
Posted: Mon Dec 11, 2017 7:41 pm Post subject: Re: Color for gas tank - Oval Beetle |
Their computer printed label said 8:1 but the label on the can said 4:1. I called them to verify.
TCP said 4 parts paint, one part hardener. Reducer is not recommended because it has a little already because it isn't full gloss. He also said "do not spray real wet, medium is fine". |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Wed Dec 13, 2017 10:02 am Post subject: Re: Color for gas tank - Oval Beetle |
... i'd paint it black... black just looks nicer. Gray is so blah
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
billb Samba Member
Posted: Wed Dec 13, 2017 10:46 am Post subject: Re: Color for gas tank - Oval Beetle |
ZENVWDRIVER wrote: |
... i'd paint it black... black just looks nicer. Gray is so blah |
I am trying to keep my car as close to how it came from the factory as possible. It won't be perfect but getting those details right takes time and to me is worth the effort. |
