64 ragtop volks Samba Member
Posted: Fri Oct 10, 2014 8:19 am Post subject: |
dmuis Samba Member
Joined: September 01, 2004 Posts: 381 Location: Sunny Alberta, Wild Rose Country.
Posted: Fri Oct 10, 2014 8:49 am Post subject: |
Got pics of the whole bus with these!?!?
srfndoc Samba Member
Posted: Fri Oct 10, 2014 9:08 am Post subject: |
Check out his gallery. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches
Posted: Fri Oct 10, 2014 9:10 am Post subject: |
i have 18"from bottom of rocker to the ground.bay front beam,and added some camber to the rear to level it out. |
tarzan271 Samba Member
Joined: October 20, 2003 Posts: 336 Location: Santa Rosa, CA
Posted: Fri Oct 10, 2014 11:02 am Post subject: |
Here I am driving last week.
_________________ ~Tarzan
1964 Deluxe Bus - Sold |
lillaRe Samba Member
Joined: August 23, 2009 Posts: 60 Location: Ijamsville, MD
Posted: Fri Oct 10, 2014 11:49 am Post subject: |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1106 Location: Burlington, WA
Posted: Fri Oct 10, 2014 8:46 pm Post subject: |
tarzan271 wrote: |
Great shot _________________ -Adam
'59 Mango Bus - getting buried in it
'69 Bug - sold and highly missed, so it stays in the sig |
sled Samba Member
Posted: Fri Oct 10, 2014 11:46 pm Post subject: |
64 ragtop volks wrote: |
if you're going to go that route you should really drop the trans in the rear to get close to zero degrees of camber (dove blue bus). this thing was a monster, I shouldnt have sold it.
_________________ drive your split. |
Posted: Sat Oct 11, 2014 7:08 am Post subject: |
Thats badass pic! Yeah a trans drop of about 1" and a bug nose cone is the way to go i have been told .a guy did a build of a 58 lifted double door a wile back on the samba from arizona lifted with 31" tires...i never understood the point of a lowered camper |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Sat Oct 11, 2014 1:36 pm Post subject: |
Is the DB Bus the one that had the one piece tie rod? How well did that work? Is is something you would recommend for general off road travel or only extreme bashing? _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
sled Samba Member
Posted: Sat Oct 11, 2014 2:07 pm Post subject: |
the blue bus had two tie rods, but they were 4130 chrome-moly with big heims at each end.
I think the biggest handling advantage though was the shock setup we built (and the expensive bilsteins)
Brian Samba Moderator
cru62 Samba Member
Posted: Sat Oct 11, 2014 3:16 pm Post subject: |
So, did you build a bus with a one-piece tie rod? Or sell them? I seem to remember seeing pics of that somewhere on this site and for some reason have associated your name with it.
Thanks for sharing your pics. While the setup you built looks simple, it is very deceiving. There is a quite a lot going on in those shots, especially the rear end. Maximum droop front and back. I bet it is a blast to wring out off road! Any other pics? _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Sat Oct 11, 2014 4:49 pm Post subject: |
A few of my favourites.
_________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
sled Samba Member
Posted: Sat Oct 11, 2014 6:44 pm Post subject: |
cru62 wrote: |
So, did you build a bus with a one-piece tie rod |
no, I havent done that and honestly it is not a good idea. having both wheels connected is a no no
here's the trans drop. I dropped the horns into the cradle so I wouldnt lose any ground clearance. Full 2" trans drop if I remember right.
2-1/2" lift spindles welded by the master, Cameron Johnson.
cutting brakes using two original mechanisms sharing a common pivot pin.
1700 stroker with 15 gal fuel cell
Andy P Samba Member
Joined: February 04, 2001 Posts: 1166 Location: NSW, Australia.
Posted: Sun Oct 12, 2014 5:10 am Post subject: |
So, is it really necessary to raise your tranny and go BJ if you want to take it off road a little? _________________ Cheers & God Bless
'62 Beetle
Jägdwagen |
Posted: Sun Oct 12, 2014 8:53 am Post subject: |
No. Does it help? Yes. Does it look cool? Hell yea. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
sled Samba Member
Posted: Sun Oct 12, 2014 9:08 am Post subject: |
Andy P wrote: |
So, is it really necessary to raise your tranny and go BJ if you want to take it off road a little? |
no, throw some good all terrain tires on a stock bus and it will do amazing things with a competent driver.
but when you modify things you can do just that much more. I beat the hell out of that bus and took it places that a stock bus would not go. I also took it on a friends dirt bike track and jumped it.
It didn't have the nicest body or anything, so I would use the cutting brakes and trees to pivot around, negotiating very tight spaces.
here is Cameron's bus we dubbed the Swamp Thing!! it looked like it came out of a swamp when he got it and he put it on Super Swampers! It had the identical suspension/transmission setup as my blue bus. We built the two buses simultaneously.
Posted: Sun Oct 12, 2014 12:57 pm Post subject: |
^^^oh hell yes!!! ^^^ thats the route i might take when i do raised spindles |
