bigturkey Samba Member
Posted: Wed Dec 01, 2004 9:28 pm Post subject: can I run HVLP with my compressor? 6.5cfm at 40 psi |
Hey,
I just got an amazing deal on a Sata NR2000 and I'll be painting my car soon. I've been using a Husky HVLP gun with my small 13 gallon 6.5CFM at 40 PSI compressor. My husky gun as been working fin when I crank the regulator on the compressor to 50 PSI. What I'm wondering is this: Will I be able to use a my SATA effectively? Am I taking advantage of the HVLP technology at all really. Thanks |
BIG MAC Samba Member
Joined: August 28, 2003 Posts: 105 Location: Hemet, Ca
Posted: Wed Dec 01, 2004 11:24 pm Post subject: |
That gun is going to require about 13-14 cfm @ 50lbs. The compressor will not hang on for long, as soon as the pressure starts to drop so will all of the paint atomization. |
desrat Samba Member
Posted: Tue Dec 07, 2004 5:48 pm Post subject: |
Big Mac is right on the money with the cfm rating. You might be better off with a LVLP (low volume:CFM, low pressure) spray gun. There are several out there to choose from but most are higher $$.I have been using the Optima brand which has the Euro 900 which works off 7 cfm at 30PSI. |
Big Jim Samba Member
Posted: Wed Dec 08, 2004 1:48 am Post subject: |
You bought a really good gun. Now, you need more compressor. A second unit of about 10 cfm in parallel with your current one could be a lower cost option. |
Bklyn63 Samba Mafioso
Joined: August 24, 2002 Posts: 966 Location: "What am I, a mirage?"
Posted: Sat Dec 11, 2004 7:18 pm Post subject: |
you need 14cfm at least for a hvlp gun...12 for non hvlp gun (aka hvlp compliant gun) |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Fri Jan 14, 2005 1:56 am Post subject: |
I think the RP gun from Sata only requires 10.5 cfm. Maybe an option? |
ROGER LAWLESS Samba Member
Joined: December 18, 2004 Posts: 238 Location: SANTA CRUZ, CA
Posted: Fri Jan 14, 2005 9:52 am Post subject: SPRAY GUN |
GET A NEW COMPRESSOR FROM SEARS. THE ONE FOR $449.00 HAS A GREATER CFM THAN THE ONE FOR $559.00, ABOUT 12-13 CFM AT 50 PSI.
60 GALLON TANK ALSO. YOU WILL NEED TO HAVE A SMALL REGULATOR ATTACHED TO THE GUN TO REALY CONTROLL THE PAINT PRESSURE. 'HOME DEPOT' HAS THEM FOR $14.95, 'HUSKY BRAND.
BIG TROUBLE IF YOU DO NOT HAVE WATER TRAP IN THE SYSTEM ABOUT 10-20 FEET AWAY FROM THE COMPRESSOR. YOU CAN HARD PIPE YOUR SUPPLY LINE IN WITH 'PVC' PIPE. THEN PLACE THE WATER TRAP IN AT THAT POINT THEN ADD A COUPLING FOR YOUR FLEXIBLE HOSE, 50' +, REGULATOR AND GUN.
ROGER |
Posted: Fri Jan 14, 2005 1:19 pm Post subject: |
my sata rp is at 10.3 cfm @ 29psi....
I got the husky 60 gallon for $429 at home depot ..works great. |
Blaubus Samba Member
Posted: Fri Jan 14, 2005 8:03 pm Post subject: |
buy the sata and bolster CFM with a second compressor. if you are painting small parts you dont need the CFM or a large tank. i own a sata NR2000 and i spray engine tin with a sears pancake compressor! thats only a 4 gal. tank, with 5CFM. you can probably spray the fenders of a bug with what you got, but the body of the bug will need more CFM and/ or a larger tank, because you will need to run the gun continously
note about air flow. with HVLP the hose and coupler needs to be 3/8" (with no restrictive swivel fittings). using a regulator on the wall AND the gun will impede air flow, and yet you will need to read 28lbs "at the gun" for proper atomization etc. SO, i omitted the gun regulator and use just a gauge at the gun mounted on a tee fitting.
this requires that you adjust pressure at the wall while looking at the gauge on the gun (with the trigger pulled). there are many who will say that this method makes it hard to change settings without going to the wall regulator. but unless you are a pro with several years experience doing this work day after day, you shouldnt change settings anyway... with some practice you will get a feel for how fast to move the gun, and changing settings will just mess you up and lead to more runs. find a slow setting that wont overwhelm the window frames, and do you whole car on that setting. |
